misfire 76
Old Jul 17, 2019 | 12:08 PM
Roll's Avatar
Roll
misfire 76
Hello,
recently purchased a 1976 f150 with 360. it had sat, so carb was rough...i've since had that rebuilt. However there seems to be a misfire, and not always. not sure if its my imagination but seems to act up when the engine is warm. one thing that does concern me is the 2 centre plug wires touch (those 2 spark plugs face angle in towards each other)...any thoughts?
thanks in advance,
Old Jul 17, 2019 | 12:24 PM
Ethan5610's Avatar
Ethan5610
Now when you say a misfire you mean the engine starts running rough or you hear a loud bang/pop and then it goes back to normal? If it starts running rough i would say check the obvious plugs wires etc.. The plugs shielding touching unless exposed internally isn't really a major concern. If you hear a loud pop then that tells me your carb needs better adjusting or you might have an issue with the carb.
Old Jul 17, 2019 | 12:29 PM
Roll's Avatar
Roll
Thanks for the response. yes it runs very rough and you can hear it in the exhaust that its not running correctly on all cylinders. the carb was rebuilt by an older gentlemen who set it to factory specs (hes been doing this for 40+ years) so I think the carb is more or less running correctly. is it possible the coil is acting sporadic?
Old Jul 17, 2019 | 01:01 PM
Ethan5610's Avatar
Ethan5610
So when the motor is not at optimum temperature it runs fine but when it gets to optimum temperature it starts to run rough. It could be a vacuum issue it could be an issue with the coil not as likely. I would check that all your vacuum lines are on i would get it to optimum temp and use a mechanics stethoscope to listen and check to see if you can determine if its misfiring from 1 or multiple cylinders.
Old Jul 17, 2019 | 01:08 PM
Roll's Avatar
Roll
thanks! Ill give that a shot!
Old Jul 17, 2019 | 02:49 PM
caravaggio2000's Avatar
caravaggio2000
Assuming you have the plugs in the right firing order, have you checked the timing?
Old Jul 17, 2019 | 03:21 PM
Roll's Avatar
Roll
The firing order is correct...however I have not touched the timing, nor do I think it has been tampered with...however I was hoping to check that out as well, thanks!
Old Jul 17, 2019 | 03:23 PM
Redrokin09's Avatar
Redrokin09
Maybe heat soak issue with the Dura spark box, maybe a pick-up coil, could a lot of things. Timing?
Take a video of it running rough. that would help better diagnose the issue.
Old Jul 17, 2019 | 03:29 PM
Roll's Avatar
Roll
perfect, i really appreciate everyone's input! Ill take a look at all these possibilities and hopefully get
the old girl running like a top!
Old Jul 17, 2019 | 03:31 PM
dlburch's Avatar
dlburch
also make sure the choke is fully open after the engine warms up...
Old Jul 17, 2019 | 03:59 PM
Tedster9's Avatar
Tedster9
Always check engine compression first thing, it's best to know what you actually have to work with from a basic mechanical or engine health standpoint. Engine vacuum test will reveal other problems too. If the engine is pooched you want to know that before spending much time or money on it.
Matthew Hoffman
Nov 27, 2017 11:05 PM
Trucklover22
Aug 19, 2016 09:43 PM
TurdSandwich
May 17, 2010 09:42 PM
cool 48
38
Feb 5, 2008 09:38 AM
Farmers Ford
Jan 25, 2003 06:42 PM
