New rig
Old May 2, 2023 | 03:48 PM
WestwardHo's Avatar
WestwardHo
6th Gear
New rig
Just wanted to say hi and thank everyone for all the awesome info on here. I picked up a 92 F-250 4x4 for 3 grand a couple weeks ago. Pic of the good side below. The bad side has sideswipe damage on every panel. The door closes and the frame is straight but I've got a lot of hammer and dolly time ahead of me. So far I've changed tires, fluids and filters, deleted the smog pump and had someone who knows what they're doing fix the drums in the rear. They were flat out dangerous on the drive home.
The 351 is running good and the trans seems solid so far. The previous owner was a heavy smoker so I pulled all the old insulation out, replaced it with dynamat and steamed the bench seat and the headliner. Smell is totally gone as far as I can tell. Next on my list is a windshield and then pulling the ECM to see if I have any capacitor leakage. This thing rides like crap but it's a hell of a lot of fun to drive so maybe a front coil conversion in the future. Any tips/advice would be greatly appreciated. Looking forward to lots of time learning on here.
Old May 2, 2023 | 04:04 PM
Toork's Avatar
Toork
Looks great! In edition to general maintenance, I would go ahead and replace all the vacuum lines.
Old May 3, 2023 | 08:42 AM
WestwardHo's Avatar
WestwardHo
6th Gear
Thanks! I'll add that to my list
Old May 3, 2023 | 08:49 AM
1Butcher's Avatar
1Butcher
Where in Washington are you located?
Old May 3, 2023 | 09:50 AM
WestwardHo's Avatar
WestwardHo
6th Gear
A little south of Olympia in the Tenino area
Old May 4, 2023 | 09:23 AM
Edgethis's Avatar
Edgethis
Welcome! Thats a nice looking truck. Does the dynamite make the cab quieter then with stock insulation?
Old May 5, 2023 | 07:21 AM
WestwardHo's Avatar
WestwardHo
6th Gear
I think so? It's tough to say because I redid the weather stripping on the doors but everything is definitely quieter now. One good tip I learned is to wait for a sunny day to apply the dynamat. The glue works way better when it can warm up in the sun and the application surface is a little warmer.
Old May 9, 2023 | 12:22 AM
TobyB's Avatar
TobyB
For the ride, you might try replacing the plastic slippers between the leaves first. They wear out and bind-
I put new front springs on, and it got a lot better, but then realized that the stock sliders were completely
worn out, and the leaves had galled together.
There is universal material to replace the sliders, but I didn't have any luck finding the OE Ford versions.
t
Old May 9, 2023 | 08:39 AM
WestwardHo's Avatar
WestwardHo
6th Gear
t
Thanks! Do you mind providing a link if you have one? I'm doing some googling for leaf spring slippers but I'm not sure I'm finding the right thing.
Old May 9, 2023 | 01:02 PM
sswari's Avatar
sswari
When I did the carpet and head liner in my F150, is scraped the old sound mat out, and replaced it with Stinger X, I got the extra thick pad and carpet, deadened the doors and ceiling. Made a ton of difference. Also did all of the weather striping, so that didn't hurt.
2five7
Jan 11, 2022 07:23 AM
evan_nugget
Projects
Sep 21, 2021 07:44 AM
RustyTank
Jan 20, 2019 11:54 PM
soundmanford
26
Mar 28, 2017 08:46 PM
EcoBoosted
52
Nov 18, 2012 07:25 PM
