5 Gallon Rotella T5
Old Apr 26, 2023 | 02:56 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
5 Gallon Rotella T5
Tractor Supply has it for $59.99. Is that a good price?
Old Apr 26, 2023 | 03:58 PM
Tpayne621's Avatar
Tpayne621
Yes, it's a good deal. If you can find some it's worth getting a couple buckets. It's been going on for month or 2 now. All the stores around me are sold out. It's been posted a few times on here.
Old Apr 26, 2023 | 04:08 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I see you have a 350... Time to test the payload of the bed and get some oil, pallet style.
Old Apr 26, 2023 | 08:05 PM
Whitey Ford
Right, never used synthetic, but for that price we are willing to try. After 500,000 miles hope the 7.3 doesn’t rebel. Thank you for the responses!
Old Apr 27, 2023 | 07:11 AM
BillyBob69's Avatar
BillyBob69
I have used nothing but Rotella T6 in my old 99 since I bought her almost 300K miles ago in 2006. I switched to synthetic for all of our engines here long ago. Both cars, the truck and tractor and the boat. Have had 0 issues with engine wear and even sent oils samples in at 7500 miles on an oil change and was told results show still good.
Tractor Supply....I am going for feed this week. I may have to take a look and grab a big pail. Normally I am used to paying $100 for 4 single gallons. At nearly half price, I am gonna take the trailer with me!
Old Apr 27, 2023 | 07:50 AM
Tpayne621's Avatar
Tpayne621
You can look online and see which stores have it in stock around you and how many. The stores around me sold out in about a week.
Old Apr 28, 2023 | 10:39 AM
carl2591's Avatar
carl2591
I switch for a bit from delo 15w40 to a 10w40 t6 and did not notice any difference other than a bit more oil usage.. switched back to TS 15w40 and good to go for less.. 2.5 gallon for like 28 -32 bucks is good price. I change 5K and run a bypass filter as well on oil and when my CAT SOS oil analysis come back i get NO soot in oil numbers.
Old Apr 28, 2023 | 05:32 PM
Whitey Ford
The truck was raised on Delo until the formulation change and “the list.” Can I extend the oil change with the T5, or just keep doing it at 5k?
Old Apr 28, 2023 | 05:47 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Every 7.3L behaves differently at this point. Your best bet is to perform a couple of UOA's and make an informed decision instead of listening to a bunch of crazies like us.
My UOA adventure is here: https://www.ford-trucks.com/forums/1...?highlight=Uoa
Old Apr 28, 2023 | 08:25 PM
Whitey Ford
Do you have a thread number for the summation? Thanks!
Old Apr 29, 2023 | 08:26 AM
Sous's Avatar
Sous
FTE Emeritus
No conclusion as of yet, but the cliff notes version for the documentation thus far is below.
- Triax failed to perform as a premium oil (for me and others) and it comes as no surprise after finding out "they" were sued for fraud.
- The T6 in my truck is about 1,000 miles from being sent out for UOA and I expect it to garner good results.
- TSC Travelers is tried and true, but since it is a conventional oil, OCI intervals based on vehicle specific UOA should be adhered to.
Old Apr 29, 2023 | 08:30 AM
BillyBob69's Avatar
BillyBob69
So the local tractor supply here has the oil but not the 5 gallon buckets... at least not for that price. Ah well.
Compression-Ignition
6.7L Power Stroke Diesel
Sep 29, 2022 07:24 AM
jschira
Oil & Lubrication
Aug 13, 2020 10:52 AM
Krazyhorse
Jan 10, 2018 09:37 PM
nlemerise
May 21, 2015 02:18 PM
HH60FE
13
Oct 26, 2009 01:20 PM
