330FT rebuild question
Old Apr 24, 2023 | 06:14 PM
j80's Avatar
j80
Trailering
I have a 78 f350 dump truck. It used to be a uhaul truck with the 330Ft motor. I'm leaning towards just rebuilding the 330 due to the fact I just put new exhaust manifolds on and built a full exhaust for this motor. It has the np435 transmission. Is there a cam or anything available to upgrade the performance of the this motor. I am not opposed to swapping motors if there is anything that would bolt to the transmission with the larger clutch. It currently uses the side motor mounts and not the timing cover mount like the larger trucks.
Old Apr 24, 2023 | 08:08 PM
bulletpruf's Avatar
bulletpruf
Try this thread. https://www.ford-trucks.com/forums/6...-fe-or-ft.html
I'd say start over with a 390 if you can find a cheap one, but I don't think it will work with your trans.
FE performance parts should work, but if it was mine, I'd just get it running good and save my $ for 390.
Old Apr 24, 2023 | 08:14 PM
j80's Avatar
j80
Trailering
I just found a complete 391ft in unknown condition for $100. I have always been a chevy guy and know nothing about fords but from what I have found lately there is not much available for the FT engines as far as performance parts. I probably will look for an fe based replacement. Thanks
Old Apr 24, 2023 | 08:17 PM
bulletpruf's Avatar
bulletpruf
The 391 crankshaft apparently has some value, but I'd still pass on it and wait for an FE if you have any thoughts of performance upgrades.
Some good info here - https://www.ford-trucks.com/forums/6...d-a-391-a.html
Old Apr 24, 2023 | 08:37 PM
j80's Avatar
j80
Trailering
For an occasional use truck it's getting me by. I'm just thinking long term something I can do for more power or low end torque. I think I will wait and look for an fe motor that I can get performance parts for if need be.
Old Apr 24, 2023 | 08:54 PM
bulletpruf's Avatar
bulletpruf
Keep your eyes peeled for an inexpensive 390, but they're not nearly as plentiful and cheap as they used to be.
Old Apr 24, 2023 | 11:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are two different 330 2V FT engines: Medium Duty that uses the 352/360 crank and a Heavy Duty that used the 361 FT crank.
1973/78 F350 U-Hauls used the 330 2V Medium Duty engine.
Old Apr 25, 2023 | 10:24 AM
5851a's Avatar
5851a
FT engines are meant to take a lot of abuse that regular FE engines are not meant for. Wide open throttle for miles on end no matter the temperature. A reason for low compression. If it's getting the job done for you I would stick with what you have.
Old Apr 26, 2023 | 05:56 PM
j80's Avatar
j80
Trailering
Does anyone know if the 391 would bolt right in like the 330 as far as exhaust manifolds clutch and bell housing.
Old Apr 26, 2023 | 08:36 PM
j80's Avatar
j80
Trailering
Or does anyone know what parts are interchangeable between them. For $100 for the 391 I wouldn't care if I ended up not swapping them if any of the parts could be used for the 330 like the intake or manifolds or heads
Old Apr 27, 2023 | 10:46 AM
flowney's Avatar
flowney
If you decide to keep the 330 or switch to the 391 engine it's best to aim at a stock rebuild because there are very few aftermarket HP offerings. The regular FEs (360 and 390) on the other hand have a very healthy HP aftermarket because they are so similar to the 427/428s which are also FE engines.
tceriani
Dec 29, 2021 08:51 PM
2000PSD BlackThunder
67
Feb 14, 2008 03:30 PM
I6power
Jul 25, 2005 04:09 PM
biggut
Mar 29, 2005 12:44 AM
