Anyone using plug and play aftermarket LED taillights?
Old Feb 18, 2023 | 09:41 AM
Mikec35's Avatar
Mikec35
My taillight lens are so faded and the backup lamps are virtually useless. I am looking for a simple swap, if there is such a thing. Anyone have any good leads?
Old Feb 18, 2023 | 10:10 AM
FordTruckNoob's Avatar
FordTruckNoob
I simply replaced the bulbs with LED equivalents and put in an LED-specific blinker relay.
Old Feb 19, 2023 | 08:45 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
In addition to brighter LED bulbs, have you tried to restore the housing?
Some DEET will offer a temporary finish or you can get a kit from the parts stores or most online large retailers.
I am a big fan of Meguiars Ultimate Compound and a buffer as it will do wonders for faded surfaces. I recently used some to polish and smooth a wood bar top with 5 coats of hardwood floor polyurethane. I also use the polish on plastics, paint and gel coat over fiberglass. I follow up with a UV protectant wax after the polish.
Might be worth a few minutes of your time and a few dollars.
Old Feb 19, 2023 | 08:35 PM
Tpayne621's Avatar
Tpayne621
I have these on mine. Work great.
AKKON - For 1997-2003 Ford F150 | 1999-07 F-Series Super Duty LED Tube Style Black Taillights Taillamp Pair Set https://a.co/d/7nMEDO4
Old Feb 20, 2023 | 12:53 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I installed LED backup light bulbs and the increase in light output was very satisfactory. Plug and play.
LED 3156, something like
this this
Old Feb 20, 2023 | 04:44 AM
John in OkieLand's Avatar
John in OkieLand
the only LEDs for an Excursion look like crap, and in the small print, it says "bulbs not included"
and that makes it okay for the Amazon vendor to call it an LED tail light assembly?
Old Feb 20, 2023 | 04:33 PM
Tpayne621's Avatar
Tpayne621
IPCW LEDT-502CB Bermuda Black LED Tail Lamp - Pair https://a.co/d/e0OL6Ab
Old Feb 20, 2023 | 05:41 PM
kd5zll's Avatar
kd5zll
Put some on my 2016 f150... and they throw a lot of static to the radio when you brake. So maybe dont go super cheap like i did.
Gunnerboy
Mar 27, 2017 12:32 PM
Jonnys.1991
Feb 22, 2016 02:11 PM
ryito1122334455
Dec 31, 2011 11:39 AM
