1999 7.3 won’t start
Old Feb 15, 2023 | 11:36 PM
Keaton.m's Avatar
Keaton.m
1st Gear
I have a 99 7.3 that I’ve dumped way too much money into. I just rebuilt the transmission and everything was going great until it wasn’t. I started it to move it across the street and when I went to start it again it wouldn’t start. I can hear the fuel pump and all the lights work but when I turn it over it just makes one click. I replaced the starter and it’s still doing the same thing. Any ideas?
Old Feb 16, 2023 | 03:02 AM
udsuth78's Avatar
udsuth78
Are we talking about a manual or auto transmission? I'm going w/ auto cause it's what I'm familiar w/. Have you tried holding up on the shift lever while turning the key or shifting to neutral and giving her a go? Pretty common issues for the auto trucks are loose bolts at the end of the shift tube preventing the shifter from pulling the cable far enough for the range sensor to register "P". A simple get you out of a bind "hack" is to just jump the relay on the passenger inner fender. If the batteries and cables are good it will crank, and if the key is on and it's capable of running it will start. Here's the down side, if the truck happens to be in gear when you do this it will start and it will drive off on it's own. So be very certain that you are in P or N or better yet someone is in the cab w/ foot on the brake.
Old Feb 16, 2023 | 04:48 AM
Walleye Hunter's Avatar
Walleye Hunter
I'd start by ensuring that the batteries and their connections are good. All of the connections, the grounds and the power.
Old Feb 16, 2023 | 06:02 AM
Kwikkordead's Avatar
Kwikkordead
Put a bar on the front pulley and make sure the engine assembly hasn't locked up for whatever reason.
Old Feb 16, 2023 | 08:38 AM
S-squatch's Avatar
S-squatch
Assuming batteries are good
check the start solenoid for power, have a helper put the ignition in crank position, check the other two wires for power.
At the starter, chock the wheels, check for power at the large wire, have helper crank, check for power on both wires. The important thing here is the circuit needs to be trying to energize the starter when testing. Also test on the stud not the wire connector, if you don't have power at the stud check on the wire connector.
your test light should be bright during this, if it is dim you have a problem, if this checks out test the ground at the starter case.
Victor Aguilar
May 29, 2024 09:22 PM
coastal stone
Apr 4, 2011 09:01 PM
matconger
Jun 22, 2010 09:28 AM
mantecans
May 8, 2010 07:32 PM
69cruiser
Mar 4, 2009 09:18 PM
