2017 6.7L Coolant Leak
Old Jan 11, 2023 | 01:33 PM
PwerStroke99's Avatar
PwerStroke99
130K miles and just recentyl developed a coolant leak. I think its the Water Pump. Any other common causes of coolant leaks? I read somewhere may be some sort of O-ring?
Old Jan 11, 2023 | 06:57 PM
colossians3:23's Avatar
colossians3:23
At 130K, the water pump I would think would be the most likely culprit, but the oring in the lower radiator hose on the engine side is a common one along with the turbo coolant line at the rubber hose connection near the thermostat housing.
Hope that helps
Old Jan 12, 2023 | 07:03 AM
ToMang07's Avatar
ToMang07
Not being an ***....but there is a lot of places coolant could be leaking from. Gotta chase it down. Throwing parts to hope you got it is wasting money.
Old Jan 12, 2023 | 07:38 AM
JoeUser's Avatar
JoeUser
Everyone should have something like this in their garage, they're invaluable for finding leaks.
Amazon Amazon
Old Jan 12, 2023 | 08:12 AM
Greaser007's Avatar
Greaser007
https://www.amazon.com/28-Piece-Univ.../dp/B08B73VQQ9
I bought the similar kit from Harbor Freight to chase down a 'suspect' possible head gasket issue for overheating.
Pumped my system to 25 lbs for overnight and had no leak-down. Problem was a faulty Fan Clutch on a '95 Isuzu Rodeo 3.2L V-6.
O-Rings on remote reservoir PS systems return line are notoriuos for leaking and the return line fitting sucking air (same with hyd wood splitter lines).
Old Jan 12, 2023 | 10:32 AM
PwerStroke99
Definitely not going to be throwing parts at it. I am suspecting the water pump. I have an appointment to get it in and get it repaired. I had heard about the Orings so was asking about those
Old Jan 12, 2023 | 10:34 AM
PwerStroke99
Hope that helps
Thanks. I have a small leak at the left front bumper. Havent been able to climb underneath in this cold/snowy weather, LOL
Old Jan 13, 2023 | 10:43 AM
HRTKD's Avatar
HRTKD
The coolant lines running on top of the engine have been known to leak at the connectors.
Old Jan 18, 2023 | 05:42 PM
PwerStroke99
Update...
Upper radiator Hose O-ring was bad. all good now and back on the road
Old Jan 18, 2023 | 08:24 PM
FishOnOne's Avatar
FishOnOne
Update...
Thanks for the follow up.
What ever happened to a simple radiator hose clamp?
BlueBeauty
Oct 2, 2023 03:22 PM
ithaca1230
Dec 6, 2022 01:35 PM
josh07797
3.0L V6
May 3, 2022 09:23 PM
tigerlady1221
Jan 27, 2016 04:45 PM
98FordTruck
1997 - 2003 F150
Jan 14, 2009 09:13 AM
