coolant leak
Old Nov 29, 2022 | 09:11 AM
ithaca1230's Avatar
ithaca1230
coolant leak
Hello all. I have a coolant leak from what appears to be a Y fitting on passenger side that connects to hoses. I tried to find this part and cannot. Called dealer and was told not available. Do any of you have a fix for this. Thanks Billy
Old Nov 30, 2022 | 07:49 AM
bajaphile's Avatar
bajaphile
What engine do you have? A pic would be helpful.
Old Nov 30, 2022 | 08:57 AM
ShelbyHauler's Avatar
ShelbyHauler
A Y fitting or a T fitting? On my 04 6.8 V10 I recently had a T fitting on the passenger side behind the engine start leaking. Look at the end of this thread if this is what yu have. https://www.ford-trucks.com/forums/1...lant-leak.html
Old Nov 30, 2022 | 09:04 AM
ithaca1230's Avatar
ithaca1230
6l diesel motor
Old Nov 30, 2022 | 01:30 PM
ithaca1230's Avatar
ithaca1230
Found a replacement hose assembly. Gonna replace tonight. Thanks
Old Dec 6, 2022 | 01:35 PM
ithaca1230's Avatar
ithaca1230
Well after getting the wrong part twice once from local supplier and then from Ford dealer I cut the hoses off at the end of the y fitting and used shark bite fittings with hose clamps to replace. It seems like you would have to remove the AC unit and the heater core to get to the end of the hose.
Kdawg89
Dec 19, 2021 09:01 AM
JVR
Sep 30, 2018 03:57 PM
jereli
Jan 14, 2014 11:11 PM
texan2004
Jul 7, 2008 09:46 PM
brej
Mar 22, 2005 07:45 PM
