2002 Ford Excursion Tank sock *Help Appreciated*
Old Dec 9, 2022 | 10:27 PM
sterling's Avatar
sterling
Twice now my longtime Ford excursion has left me on the side of the road. I Left Daytona Beach heading to Tampa towing a 7k lb trailer at about the 160 mile mark it started losing power and skipping. I had towed back to Daytona where it started running fine again before diag so my mechanic replaced the ICP sensor ( I cant remember the code) but he mentioned low fuel rail pressure code..8 Motorcraft injectors were installed 8k miles prior.
2nd break down..Last week I left Daytona towing the same trailer and got to almost the same location and it happened again, power loss/chugging under power. This time I had towed to local Dealer "Gator Ford" They called and said the tank sock was most likely clogged...they said they need to clean the tank and sock..right at $980.00. (Auto Nation quoted me 1500) I am hopeful this fixed it but I am nervous to pu and take on another trip (I hate breaking down) especially on I4.
Has anyone else experienced anything like this?
Thanks
Old Dec 9, 2022 | 10:53 PM
udsuth78's Avatar
udsuth78
The in tank filter screens are a common failure for these trucks. Most people end up deleting them and redoing the fuel pick-up. It's referred to as the Hutch Mod. Oh, btw there are no fuel rail pressure codes of any kind for these engines. The PCM actually has no means of monitoring any part of the fuel system other than fuel pump on or not.
Old Dec 10, 2022 | 05:28 AM
FordTruckNoob's Avatar
FordTruckNoob
I have this sitting inside my tank and it has worked very very well.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Dec 10, 2022 | 06:43 AM
sterling's Avatar
sterling
Ok thank you
Old Dec 10, 2022 | 06:57 AM
SkySkiJason's Avatar
SkySkiJason
$30 in parts and 2hrs labor.
You’ll see in these pics why truck runs out of fuel.
https://www.ford-trucks.com/forums/1...poon-mods.html
Old Dec 10, 2022 | 07:37 AM
Kwikkordead's Avatar
Kwikkordead
I like that aftermarket filter idea a lot. Ford should have done that in the beginning. What do you do for the screen inside the fuel pump? Mine was so full of crud that it would have filled a tablespoon if I could have gotten it out of there. That one reason alone is why I decided to dump the Ford idea and make my own.
Old Dec 10, 2022 | 08:08 AM
SkySkiJason
Originally Posted by Kwikkordead
I like that aftermarket filter idea a lot. Ford should have done that in the beginning. What do you do for the screen inside the fuel pump? .
Yes, a filter you can INSPECT for water, debris or air intrusion does seem pretty smart. Being able to replace it without dropping the tank is brilliant! lol. Additionally, the umbrella/shower head piece will fail eventually. I rarely remove one that was intact.
I stop stuff from getting into the pump in the first place with the WIX 33972. Most people never need to change this filter. It’s really just an ‘oh crap, I put nasty fuel in the tank’ option to dropping the tank.
I’ve used the RACOR PS120 as an option for cab chassis trucks (steel tanks) that had failing liners because of its massive dirt-holding capacity and the fact it is cleanable/reusable.
william_04_x
May 4, 2020 11:18 AM
sdm300
May 13, 2019 08:51 AM
bad_idea
Jul 5, 2018 09:14 PM
SDTruckMan
Nov 2, 2017 06:04 PM
Spoojr
Aug 2, 2017 11:16 PM
