New clutch, disengagement issue
Old Apr 12, 2022 | 10:26 PM
jackdichiara_03's Avatar
jackdichiara_03
1994 f150 with m5r2. Just replaced clutch, pressure plate, flywheel, pilot bearing, master and slave (with release bearing). Clutch, pressure plate, and hydraulics are Luk brand. With the rear wheels off the ground, the trans is harder than it should be to get into gear and when putting it in first the rear wheels try to spin a little bit which clearly tells me the clutch is dragging.
I jacked the front of the truck higher than the rear and tried gravity bleeding, depressing the clutch and cracking the bleeder then releasing, pumping the clutch then cracking the bleeder, pumping the clutch and letting it pop back up, and various other techniques and I've never even gotten any air out of the bleeder and the problem remains. Weird thing is the pedal feels nice and solid as it should. The pedal bushings and linkage all look good and look solid while the clutch is being depressed. The slave cylinder seems to be moving the correct amount when observing through the bellhousing but I don't know exactly how much it should move just by looking at it. Thoughts?
Old Apr 13, 2022 | 06:59 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Clutch disk facing the right way?
Old Apr 13, 2022 | 07:47 AM
jackdichiara_03
Yes, 100% sure it’s facing the right way.
Old Apr 13, 2022 | 09:47 AM
PRIMERED79 SHORT BED's Avatar
Did you bench bleed the master cylinder with the hose attached before install?
Old Apr 13, 2022 | 09:56 AM
Hit Man X's Avatar
Hit Man X
I was thinking this also, unless the kit was prebled.
Have you ever done pedal box bushings? They do wear. Is the pivot lever in good shape with the small bushing in place?
Old Apr 13, 2022 | 10:38 AM
jackdichiara_03
The hose and master came pre filled as an assembly.
Old Apr 13, 2022 | 10:40 AM
jackdichiara_03
I haven’t replaced them no, but they look to be nice and tight with no play when the clutch is depressed. And, I didn’t have this issue before I replaced the clutch so it’s definitely not the bushings.
Old Apr 13, 2022 | 12:25 PM
sevensecondsuv's Avatar
sevensecondsuv
I once had this issue. After 3 sets of master and slave cylinders and taking the trans out and back in twice, I figured out the issue was I failed to clean and lube the splines on the trans input shaft. They were dry and rusty which caused the clutch disc to not slide freely enough forward and back on the splined shaft, causing it to drag against the pressure plate.
I wire brushed (in a drill) the splines good and shiney, applied a thin coat of high-temp grease, reassembled everything and the problem was gone.
So make sure the input shaft is clean and lubed
Old Apr 13, 2022 | 12:38 PM
jackdichiara_03
The input shaft had no rust on it and I cleaned it then used the spline lubricant included with the clutch and lightly lubricated the splines. Maybe too lightly?
Old May 31, 2022 | 09:12 AM
jackdichiara_03
It turned out that the clutch was fine and was bled properly, it just needed to be bedded in and driven and now it works perfectly fine.
Old May 31, 2022 | 09:52 AM
FuzzFace2's Avatar
FuzzFace2
Good to hear you have it fixed.
On the 80's trucks, dont know if it happens on yours, 1 of the issues is the firewall cracks so when you push in the clutch pedal the master moves so you dont get a full stroke. With a helper have them push in the clutch and you watch the firewall for movement.
There are two different, small & large, firewall braces to fix or stop this from happening. Think all you can get now are the lager one, JBGY has them.
The other is if not pre-filled and no matter how much you bleed it still will not work.
They say tapping on the slave & line with a hammer will work the bubbles up to the master and start working sometimes.
The other is to just drive it and hit bumps as the vibration will work the bubbles to the top.
Dave ----
Visseroth
Apr 28, 2013 07:29 PM
octaneforce
Apr 23, 2011 07:47 AM
boots6868
Nov 10, 2008 05:09 PM
John_1953
May 17, 2007 06:09 PM
65galaxie
Dec 8, 2005 10:54 AM
