65 carburetor leak
Old Jan 18, 2022 | 08:24 AM
Fathumb's Avatar
Fathumb
65 carburetor leak
I noticed I have a leak in my carburetor after I move the throttle. I assume either the float is bad or i need to rebuilt the carburetor entirely? I attached a video below. I haven't done this before so was wanting to get some opinions on proper path forward. Engine is a 352 V8.
Thanks for the help.
File Type: mov
Old Jan 18, 2022 | 08:54 AM
hiball3985's Avatar
hiball3985
Your accelerator pump diaphragm is shot. You can purchase a new one but probably better to just get a kit and rebuild the carb..
Old Jan 18, 2022 | 01:46 PM
KO1960's Avatar
KO1960
X2. It’s not a difficult job. The kits come with an exploded diagram.
Old Jan 20, 2022 | 08:11 AM
Fathumb's Avatar
Fathumb
thanks for recommendation. The only markings are below in the picture. The numbers I see are 5752307 and 940. Does this ring a bell for anyone on which carb this is? Im not finding anything clear when I search the internet.
Old Jan 20, 2022 | 08:19 AM
KO1960's Avatar
KO1960
I don’t know what the numbers are, but it looks like a Autolite or Motorcraft 2 bbl.
Old Jan 20, 2022 | 08:46 AM
hiball3985's Avatar
hiball3985
Just an Autolite 2V as stated. There should be a tag attached to one of the screws that hold the top on if someone in the past didn't remove it. Those carbs were used on many vehicles and usually one kit fits all of them. It's one of the simplest carbs to rebuild.
Old Jan 20, 2022 | 08:48 AM
Fathumb's Avatar
Fathumb
thanks for y’all’s feed back. Someone did remove tag!
I’ll get me a rebuild kit for a autolite. Thank you for help.
Old Jan 21, 2022 | 09:28 AM
perry xxx's Avatar
perry xxx
I would go on line and talk to Mike’s Carburetor https://www.carburetor-parts.com/crm...tion=contactus they will show you how to find the numbers for your carb.
bmarble12
Feb 29, 2016 10:59 PM
kishkumen
May 25, 2014 06:54 AM
Wbruiser2
Dec 19, 2013 07:35 AM
mythbustingpyro
Sep 23, 2013 11:31 AM
FitchBanjos
13
Mar 5, 2008 06:05 PM
