Does anyone have a Heat Pump Water Heater in their garage? I’m thinking about getting one, as the garage is Hot about Six Months out of the Year, with it warm another two to three months. Thinking on the terms I could heat water, cool the garage. I’m no concerned about heating it in the winter, as it always stays well above freezing, and I do have an electric heater, if I need to do work.
I have two hybrid heat pump water heaters in the garage. They work fine down to about 45 degree ambient. After that or under heavy use the internal heating elements take over.
How do they do for cooling the garage down? BTW I’m not looking to get it super cool, as I’m used to working in the heat. 40 + years of Commercial HVAC.
They offer no noticeable cooling, slight humidity reduction but these are tiny units. My garage has its own 4 ton HVAC system for cooling.
Unless you are using HUGE amounts of water, a heat pump water heater won't do much for cooling.
It will likely lessen your electric bill as they are more efficient, but may not be worth the initial cost.
I have no first hand user experience with the so-called "instant water heaters" but they're widely touted as eliminating a large utility cost of the typical standing water heater we're all familiar with.
Heat pumps are okay for some climates and uses but I think the advantage for domestic hot water are the "instant" heaters----seems to make more sense to me.
