97 Eddie Bauer Heater Problem
Old Nov 8, 2003 | 09:00 PM
tombeks's Avatar
tombeks
I recently used the blend door fix from this forum and it worked like a charm - thankyou to whoever put it on.
I have recently noticed (since it got cold) that the heater on works when the car is moving. Does this sound farmiliar ?
Also I seem to have a minor coolent leak - the resevior is still well up but I was wondering if this has anything to do with the heater issue.
When moving, the heater controls all work normally and I can set the tem to be what ever I want and to come out of which ever vent s I want.
Thoughts welcomed
TOM
Old Nov 9, 2003 | 04:44 PM
golfboy17's Avatar
golfboy17
If your seeing coolent lose, your water pump could be going, and leaking, if you only get heat when you go it could mean that the water pump needs to be spun faster to circulate the coolent, are you experencing over heating when the its not moving? The water pump could seize up then you will have no coolent circulation, take a look at the water pump there are weep holes in it see if you see any coolent around it or coming out of them, also warm up the explorer and turn the heat on if its not comming out warm rev the engine a little and see if it will come out warm>
Old Nov 9, 2003 | 04:50 PM
tombeks's Avatar
tombeks
Thanks for that, the temp is fine when the car is running. I will check the pump for leaks tonight. Is the water pump easily visable ?
Old Nov 9, 2003 | 05:32 PM
golfboy17's Avatar
golfboy17
kind of, its on the front of the engine about half way down, you will see the lower radiator hose comming out of it look from the top and bottom.
Old Nov 9, 2003 | 07:30 PM
tombeks's Avatar
tombeks
You are completely right, from cold the heater doesnt work hwen the engine is up to temp until you step on gas and get the revs over 2000 rpm. Also the temp gauge did go up a fair way until the coolent started to flow. When it starts to flow I could hear a series of bubbles and then heat came pouring out of the vents.
The car has a 2 year powertrain cover on it and so I will only have to pay the 1st 90 bucks to get the pump changed.
I had a look at the pump, I couldnt see any leaks from it, only from a rubber hose that has a metal junction in at the bottom of the engine (view from underneath) I dont know if it is this is leakin or if it is just where the coolent gathers to drip as it is loww down on the car.
Anyway I will investigate the pump job tomorrow, so thanks for your help.
