Possible Misfire? Or blown Turbo!?!
Old Apr 24, 2021 | 10:58 AM
Gear619's Avatar
Gear619
I have a 2011 6.7 with 45,000 miles on it fully deleted and tuned .... truck has always ran amazing and I have about 1000 miles on it since it’s been deleted and it’s ran great, I run it in the stock tune 99 percent of the time .... today I was driving and out of nowhere I start hearing a ticking from the engine compartment, I kept driving and then I got to a hill and started accelerating up it and the truck was shuttering and vibrating like a misfire.... then the ticking got worse, and the truck exhaust sounded “less loud” .... I ran the diognostics on my tuner and it says there are NO codes .... the turbo seems to be building pressure like normal, I got it to 21psi on the stick tune while this was going on, it doesn’t seem like the turbo is bad .... I checked the air filter but I just cleaned it and it was fine..... I don’t know what to do any ideas?
Old Apr 24, 2021 | 12:02 PM
Just Strokin's Avatar
Just Strokin
A ticking sound is not usually attributed to a turbo or a misfire but something loose such as maybe rocker arm(s)/lifter(s)/pushrod(s). Can you determine what side is ticking of it is both sides? If you can determine only one side, then you might need to pllt that intake/valve cover to determine if you have a pushrod or rocker arm problem.
Old Apr 24, 2021 | 03:05 PM
Gear619's Avatar
Gear619
Would it be ok to drive the truck to my mechanic about 15 miles or should I have it towed
Old Apr 24, 2021 | 03:18 PM
Just Strokin
Since it is rattling, I think I would have it towed.
Old Apr 24, 2021 | 03:47 PM
Gear619's Avatar
Gear619
I drove it about 10 miles back home from where it started happening hopefully I didn’t cause any further damage!
Old Apr 24, 2021 | 04:13 PM
Gear619's Avatar
Gear619
I checked the oil and it is at the right level and didn’t seem to smell like diesel fuel .... this is very odd to me becuase it runs and drives pretty much fine other than the loud clicking/knocking noise and it shakes under low acceleration .... what amazes me is that 5 minutes before I noticed it I got on the throttle to pass someone and it was perfectly fine during that and after for 5 minutes and then boom all the sudden it started knocking ... I’ll also add that I had just filled an empty tank right before I passed that car and before it started knocking
Old Apr 24, 2021 | 06:33 PM
Marcial O.'s Avatar
Marcial O.
You might want to look inside your fuel tank. Its very possible the fuel you pumped was contaminated and is causing a fuel knock. High pressure common rail fuel systems do not like fuel contamination (too much water,gasoline,def,old fuel).
Old Apr 25, 2021 | 05:11 AM
mattymax's Avatar
mattymax
2nd that. Sounds like a possible fuel issue
Old Apr 25, 2021 | 07:04 AM
senix's Avatar
senix
drain the separator and check for water. otherwise it sounds to me like a rocker arm issue or maybe an injector issue.
Old Apr 25, 2021 | 09:44 AM
Gear619's Avatar
Gear619
yeah I brought it to the mechanic, I’m mechanically inclined but don’t trust myself enough to dig that deep into something that could cost me more money in the long run .... I hope it’s something simple and not valves smacking the piston or something catastrophic like that .... I just bought the truck a year ago from a dealer and am obviously still paying on it .... that’s the part that’s nerve racking lol
rohleder644
6.7L Power Stroke Diesel
28
Aug 12, 2020 11:50 AM
akblackfoot
Sep 6, 2016 04:14 AM
arcturner
Oct 11, 2014 10:52 AM
Dlinzy
Apr 13, 2010 12:59 PM
emmagator
Oct 14, 2007 08:13 AM
