Truck Bed Replacement
Old Apr 4, 2021 | 08:20 PM
Fordamateur's Avatar
Fordamateur
My '88 F250 doesn't have any rust in the bed, but it was definitely used to haul some heavy stuff. The bed looks a little like a roller coaster with the dips between the crossmembers.
I've looked around for just bed floor replacements but can't find anything more than patch panels. Am I going to have to buy an entire bed or is there a source to just get the floor of the bed?
Old Apr 5, 2021 | 12:13 AM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
Are you wanting a functional floor or something that looks new? If functionality is what you seek, there are other options depending on what you are hauling.
The floor in mine was rotten. When I cut out the unsound area of rust, I was left with about half a bed. The cross beams were still solid and enough of the floor remained to provide support. I went with a wooden deck made from eight foot 1x4s of "white wood" (eight foot bed). I chose boards over plywood because boards are easier to handle and when they get damaged, I only need to replace the affected boards rather than a whole ply sheet. I laid the boards out and ran sheet metal screws through the wood and remaining floor. It took about 15 boards, a box of screws, and a pint or so of oil based paint: $115 plus the paint I had on hand. Resistant enough that one board can support me (200+ lbs) standing half a brick without crushing. On areas that are unsupported between cross members, I can walk on the deck with no significant flex or sag. Designed for function, it looks good. Had I been less worried about wear/damage, I could have used marine grade stain and had a very sharp looking bed.
Old Apr 5, 2021 | 01:16 AM
Fordamateur
I just want something functional. I don't have any plans to haul anything significantly heavy, just mainly to pick up lumber and construction materials occasionally, or whatever "awesome bargain on Facebook Marketplace" my wife found this week.
I never thought of a wood floor option or anything else, my mind was just on replacing the floor of the bed with a factory floor. Now I've got all kinds of possibilities in my head!
Thanks!
Old Apr 11, 2021 | 02:39 PM
FuzzFace2's Avatar
FuzzFace2
Google search
https://www.google.com/search?q=ford...hrome&ie=UTF-8
I have seen it posted in the older truck areas that someone does make a full floor replacement just cant remember it now.
Dave ----
Old Oct 14, 2021 | 10:14 PM
tbear853's Avatar
tbear853
If one used wood, they can go back and bed line out of a gallon can of bed liner from HF, stuff works on wood. If I used wood, might check with local lumber yard or saw mill for some oak, maybe inch thick, then let it dry on the truck a month or two before bed liner.
My old Chevrolet stepside had OEM wood, oak. You could go with teak $$$.
My last trailer I made from a wrecked '79 F-150 ... I made 4 cross members of steel, included a strip for bolts at front and mid way but recess a bit at the rear for 1/8" steel across ends, Used carriage bolts to fasten 2x6 pressure treated boards to front and third cross members, then at very rear secured with a single 2x2x1/8 steel angle to protect the exposed ends to loading, that trailer was made in the '80s, still has the wood. Not mine now, but fellow has it likes it, keeps stored in his patch of woods. It tilts too, I did lower it with a flip later.
Searching for 1977 F-150 bed floor or 1977 F-150 bed parts showed me a range from generic smaller ribbed patch like panels cheap ... to complete, 17 ga, weldable primed, repros not as cheap.
wprobasco
Oct 23, 2015 07:41 PM
BaltoMoJoe
Dec 15, 2014 06:52 PM
deck60
Oct 8, 2011 09:21 PM
restoringmy46
1947 and Older Ford Trucks
Jan 21, 2005 11:22 PM
Palmer
Oct 6, 2003 01:16 PM
