Offroad & 4x4
What gear do I need in my rear end and front axle
Old Mar 26, 2021 | 06:03 PM
BASSPRO68's Avatar
BASSPRO68
Okay here's what happened hooked boat up to truck today ----20 ft procraft with 200 mercury--- my truck 12 in lifted 94 f350 4x4 5.8 351w
3 speed auto with 86 axles 4.10 gears--- dana 60 front---10.25 rear end---37 in tires 12.5 wide by 16.5----acted like it had one hell of load behind it temp climbed to 220 and stayed in that area---now every things new on this truck I mean new---engine less than 100 miles on it---radiator 3 core aluminum with dual fans 180 thermostat-----I'am thinking its the gears that causing it to feel like that it pulled it but had to lay on it every time starting off from slowing down or braking-- had some advice to put 4.88 gears in it said would increase rpm around 500 not that bad--- any thoughts on what I might should do--all thoughts welcomed--thank u
Old Mar 26, 2021 | 06:26 PM
ford390gashog's Avatar
ford390gashog
Well a C6 transmission without a lockup is going to get very hot. It also has a terrible low gear, that compounded with 37's and 4.10 gears will act as you described. I would be looking at 5.13 gears for this.
Old Mar 26, 2021 | 06:42 PM
BASSPRO68's Avatar
BASSPRO68
So the 5.13 gears should be better than the 4.88---Would they increase my rpms too much----should temp go down better with the 5.13----would it give me more get up and go than the 4.88
Old Mar 28, 2021 | 08:23 AM
Nothing Special's Avatar
Nothing Special
Did you have any experience with the 4.10 gears and stock tires (~32") with that load? 4.88 gears would put you back pretty close to that setup. That setup would give you about 2700 rpm at 60 mph, a little over 3100 at 70 mph (a C6 is not a great trans for both towing and going fast, something with an overdrive wouldn't require giving one up to get the other).
Yes, 5.13 gears would give you more get up and go than 4.88s. They'd also put you at about 2800 rpm at 60 and close to 3300 rpm at 70.
I can't say which would be a better setup for you.
Old Mar 28, 2021 | 09:30 AM
BASSPRO68's Avatar
BASSPRO68
no experience at original setup was already lifted when I got it-----what do u think is max rpm I should run at on long way like I 95 just driving it to go fishing not everyday----would 3500 be too much-----
Old Mar 29, 2021 | 11:41 AM
Nothing Special
Personally I like keeping it below about 2500 rpm. It's just to busy / buzzy above that and not pleasant to drive.
But keep in mind that when trucks were getting the C6 trans the speed limit was generally 55 mph. Like I said above, it's not a great trans for both towing and going fast, because when it was built it didn't have to go fast. So you're going to have to compromise on one or the other (or get an overdrive).
Back to "is 3500 rpm too fast?" I can't really say. It'll hold up for a while doing that. But I don't know how long "a while" is. Maybe a really long time, maybe not. And maybe others can give you a better answer.
Old Apr 1, 2021 | 01:37 AM
Team Danger's Avatar
Team Danger
How attached are you to that 12” lift? If you stepped down to say a 6” lift and a 35” tire there would be a lot less stuff pushing air.
Old Apr 7, 2021 | 03:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
a truck is going to "push the same amount of air" if it has a 24 inch lift, or stock height.
the tire size and gear ratio is what is killing the power band.
and there is no need for 6 inch lift with 35 inch tires. i have 37's on a 4 inch lift.
Old Apr 7, 2021 | 08:22 AM
Team Danger
I do agree his main issue is lack of gearing for a 351 and 37s, my thought was stepping down a tire size or two to gain better overall gearing with much less effort than swapping gears in the diffs.
lawnspecialties
Sep 6, 2017 04:50 PM
jerg_064
Ford Truck Parts for Sale
Jul 13, 2014 08:00 PM
|WYG|SS
27
Jun 11, 2010 01:57 PM
Viken
Dec 7, 2004 12:45 AM
nzirbel
May 20, 2004 12:51 AM
