1997 5.8 sd to maf conversation
Old Mar 12, 2021 | 03:56 AM
Twinned Charts's Avatar
Twinned Charts
the truck is a 1997 5.8 f250, e4od trans,
Through my research I think I’ve decided the best way to convert to maf is to add the maf intake and sensor then get a 1996 5.0 computer to plug into the 5.8 harness (will the 5.0 computer plug directly into the 6.8 harness?) and then add the wires to power and read the maf sensor
Will this work? Does anyone have any better ideas?
Old Mar 12, 2021 | 06:27 AM
rla2005's Avatar
rla2005
A 1996 MAF 5L PCM will be OBD-II. It will not plug into your harness.
Here is a better solution: https://www.stinger-performance.com/...ain-management
Next question is why you want a MAF conversion?
Old Mar 12, 2021 | 10:09 AM
jackietreehorn's Avatar
jackietreehorn
I done did it. Having to do it again, I would just buy a kit online or find an actual 5.8 MAF harness. I was getting lean codes from using a 5.0 computer on 5.8, it would require a tune.
Old Mar 12, 2021 | 04:01 PM
wwhite's Avatar
wwhite
I want your 1997 351w E4OD Speed Density computer!
Is it's code LAD1?
Why convert? Is there something wrong with your computer?
If there isn't anything wrong with your computer, I will buy it from you.
quincyj34
24
May 9, 2014 03:09 PM
Highriser4
Apr 19, 2012 10:47 PM
rjasman1974
Nov 4, 2009 08:13 AM
camccardell
36
Mar 30, 2008 01:54 PM
EgoMan
27
Jun 27, 2006 11:58 PM
