Update on new to me 89 f150
Old Jan 30, 2021 | 11:49 PM
Steven Garcia's Avatar
Steven Garcia
So I now am able to get the truck running (1989 f150 straight six manual 4 +OD) but now it doesn't go anywhere when I shift into any of the gears or reverse when i shift from reverse to 1st it kinda wants to jump forward which is very slightly but nothing. I bled the clutch line and it was good. Next should I change out the transmission fluid or how do I check if the brakes are locked.
1. I have changed the tires and the hubs do move freely
2. Truck was sitting for 16 years
3. When the truck was trailered to me it did roll of the ramp no problem didn't seem like the brakes were locked
Old Jan 31, 2021 | 10:31 AM
josiewales's Avatar
josiewales
If this is 4wd, you may have a transfer case problem. try 4wd and/or low range. Different feel?
Old Jan 31, 2021 | 11:14 AM
Steven Garcia
My apologies wrote this at 1am my time and should have chosen my words better but truck is 2wd
Old Jan 31, 2021 | 11:30 AM
Stickman'sF150's Avatar
Stickman'sF150
Clutch is bad, or transmission, or driveshaft/u- joint, or rear diff. Could be a lot of things.
Old Feb 1, 2021 | 10:13 AM
Toork's Avatar
Toork
jack up the rear end by the axle. Put the transmission in neutral. Turn the driveshaft and wheels. If the shaft turns the wheels then it’s probably your clutch.
Old Feb 1, 2021 | 10:19 AM
hobohilton's Avatar
hobohilton
I would focus the trouble shooting towards the clutch..... Could be burned out or there could be something stuck from sitting that long.
Hobo
Old Soul
Feb 26, 2020 08:50 PM
akaero
Sep 26, 2010 05:22 PM
5_StringsNoPick
Mar 26, 2007 09:10 PM
M.Stephens
Mar 22, 2005 12:44 PM
f150junkie
Sep 15, 2003 08:11 PM
