Speedometer Adjustment?
Old Feb 1, 2021 | 10:44 AM
tpage's Avatar
tpage
I think my speedometer is off by 7mph. I used multiple Heads Up Displays (HUD) on my phone to check the speed. Each HUD app showed 7mph faster than the dash speedometer. I have the stock size tires on it. Also checked by mile markers, seemed a little off.
My speedometer has the mechanical odometer, and was wondering how to adjust it. Seen online how to adjust speedometers with digital odometers, but not mechanical odometers.
87 F150, Automatic Trans, Custom Cab, 5.0L/302 EFI.
Old Feb 1, 2021 | 10:54 AM
Conanski's Avatar
Conanski
The speedo dive gear in the trans/t-case tail has to be changed, or you could upsize the tires
Old Feb 1, 2021 | 11:02 AM
tpage's Avatar
tpage
Just got new tires so the upsize will not be an option, for now...
How would you determine the new gear size?
Old Feb 1, 2021 | 11:16 AM
GNR22's Avatar
GNR22
https://lmr.com/products/Mustang-Spe...ear-Calculator
You need to find what color the speedo gear is that is attached to the shaft on your transfercase/transmission. With that information, you can determine which gear you need on the cable.
brandon4
Oct 6, 2019 09:33 AM
metru
Nov 8, 2017 09:26 PM
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
Softtopper
Feb 28, 2008 06:45 PM
str8six
1978 - 1996 Big Bronco
Oct 27, 2002 03:16 PM
