Gauges on my 53 F100
Old Nov 23, 2020 | 08:38 PM
jlamberth's Avatar
jlamberth
What is the best way to access the gauges in my 53 F100?
Old Nov 23, 2020 | 10:28 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Hey, jlamberth. If your gauges and wiring are original, you can take out the four screws holding them in, push the cluster back into the dash, turn it, and pull it out the front.
It won't pull out very far, especially with the original wires. They will be short and very brittle. Some of the insulation may even break off.
If the truck has been rewired, then it's anybody's guess how far it will pull out.
If you re-wire the dash, I recommend adding plugs. Then you can fish the instrument cluster out the front, unplug it, then remove it.
Old Nov 23, 2020 | 11:43 PM
jlamberth's Avatar
jlamberth
Many thanks Effie. I'll check it out.
Old Nov 24, 2020 | 08:16 AM
big job's Avatar
big job
Effie's got it. All my trucks have extended cable that plug in. Factory should have done
that in the first place. After disconnecting speedometer its out as fast as you remove
four screws.
Old Nov 24, 2020 | 08:55 PM
jlamberth's Avatar
jlamberth
Effie, where did you find the 8 wire connector?
Old Nov 24, 2020 | 10:30 PM
EffieTrucker
I didn’t have an 8-pin. I used a 6-pin and a 2-pin.
Old Nov 25, 2020 | 05:04 AM
big job's Avatar
big job
I used trailer wiring with male and female plugs all stores have those..
Old Nov 25, 2020 | 08:55 AM
jlamberth's Avatar
jlamberth
Good idea. I'll check them out.
Old Dec 1, 2020 | 11:19 AM
jlamberth's Avatar
jlamberth
Installed 2 - 5 wire trailer connectors and it worked great. Made the overall length addition about a foot.
Old Dec 1, 2020 | 02:27 PM
jlamberth's Avatar
jlamberth
Please see new thread Runtz Voltage Reducers problems.
mike_macd
27
Mar 25, 2014 05:24 PM
ffillah
WTB - Parts & other
Mar 14, 2012 06:18 PM
kmartic
Sep 12, 2009 09:07 PM
1972ford_f-100
Apr 1, 2004 07:54 PM
