Ford Script Questions
Old Nov 23, 2020 | 07:18 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Couple of questions about using Ford Script items on a 53-56 pickup.
I read that you can install the older script tailgates on a 53-56 short bed. What if any MODs must be done to accomplish this? Before I shell out several hundred dollars for a new tailgate I want to be SURE it can be done. I’m using a Midwest Early Ford repo bed without chains and with hidden hinges.
My next question is actually a request for a source. At the shows I’ve seen Ford Script in the front lower bed panel where the bed meets the wooden bed floor and the running boards. As shown in the circled piece in the photo below. Does anyone still make these?
Stamped Ford script???
Old Nov 23, 2020 | 07:45 AM
bigwin56f100's Avatar
bigwin56f100
I think the ford script wasn’t on the bed but on the kick up on the running board. They were on the fiberglass running boards. I haven’t seen any in years
Old Nov 23, 2020 | 08:18 AM
51fred's Avatar
51fred
I remember seeing those embossed panels years ago. Early 2000s, but haven't seen them in a while. I had thought of using them too.
I check a couple of venders and saw Macs has the separate panels. No stamp though.
Old Nov 23, 2020 | 09:13 AM
bjmayberry2
Just thought they were sorta Kool. Also saw a couple of trucks that had small toolboxes there as well.
Old Nov 23, 2020 | 10:48 AM
52 Merc's Avatar
52 Merc
Years ago, someone used to make and sell a piece of sheet metal about 12x12 inches, maybe a little bigger, that was stamped with the same Ford script that was used on tailgates. It was great for doing the little custom touches like you're talking about. I haven't seen them for a long time. My guess is they went away when Ford started cracking down on copyright and trademark infringement, and the makers were either told to cease and desist or didn't want to pay license fees on them.
The tailgates in stock form are, afaik, interchangeable, as far as size and fitment in the hole. It's been done plenty. The 53+ beds had a slightly revised latching system over the 51-2, so there may be some difference in the tab on the gate where the chains hook. If you're using a hidden latch, then that won't matter. I don't know about your hidden hinge thing, though. You may need to show us more about that.
Old Nov 23, 2020 | 10:56 AM
schoo's Avatar
schoo
here is jimmy's battery box by his knee
Old Nov 23, 2020 | 11:00 AM
bjmayberry2
Really not much to them. They just prevent all the bumping and banging the old hinges do.
Hidden Tailgate Hinges Require Welding From Speedway
Old Nov 23, 2020 | 11:58 AM
51fred's Avatar
51fred
My 51 came with a 53 and up tailgate. It worked just fine. Can't imagine any issues going the other way.
Old Nov 23, 2020 | 12:12 PM
CharlieLed's Avatar
CharlieLed
Those hinges are called "Hiding Hinges" and they are made by Pros Pick. The first set I installed were not to my liking, followed the directions but when they are mounted using a butt weld they are not very strong. Since then I have installed many of these hinges and in each case I mounted the hinge flush against the pinch weld lip of the bedside and notched the tailgate accordingly. The hinge is now very stable and is tucked into the lip of the tailgate which makes for a very clean install.
Old Nov 23, 2020 | 01:58 PM
bjmayberry2
Thanks Rich & Charlie
Also just a FYI I found some embossed Ford Script panels on fleebay https://www.ebay.com/itm/123365105660
69supercj
2009 - 2014 F150
46
Nov 27, 2017 07:53 PM
DerekShiekhi
2015 - 2020 F150
Nov 24, 2016 08:39 AM
Geoles
Sep 7, 2006 07:29 PM
3Mike6
Jul 17, 2004 04:02 PM
copeina
Oct 18, 2001 04:47 PM
