Choke cable knob
Old Aug 1, 2020 | 10:07 AM
SwampRattFord's Avatar
SwampRattFord
Choke cable ****
I'm wanting to replace my choke cable ****, it is pretty knarley and ugly. It looks to be original. Trouble is I can't figure out to get the **** of the shaft.
LMC replacement is a set screw setup but the original isn't.
Before I take my vice grips to it I thought I'd try to tap the experience here. The cable is on duty in my truck now so that makes it a little tougher to beat or grind on. I'm trying to not have to replace the entire cable to get the **** replaced.
Thanks in advance!
Old Aug 1, 2020 | 10:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by SwampRattFord
I'm wanting to replace my choke cable ****, it is pretty knarley and ugly. It looks to be original. Trouble is I can't figure out to get the **** off the shaft.
The **** was only furnished with the cable, it wasn't available by itself.
Old Aug 1, 2020 | 10:37 AM
robertrpeak's Avatar
robertrpeak
edited for the sake of humanity...don't ask
Old Aug 1, 2020 | 02:39 PM
resonateur's Avatar
resonateur
Swamp...if you can't find a way to replace the ****, I have a cable with **** that you can have for shipping cost. Let me know...
Old Aug 3, 2020 | 11:19 AM
SwampRattFord
resonateut, Thanks for the offer. At the risk of "looking a gift horse in the mouth" does the cable have a **** that is light in color or yellowed?
I attached a pic. I'm replacing them because they are yellowed and been painted at one time. If the one you are giving away is a nice light colored **** I'd take you up on it, if not I'll just buy a cable and "bite it".
AT any rat
e I appreciate the offer!
Old Aug 3, 2020 | 11:44 AM
TA455HO's Avatar
TA455HO
Lead Gopher
It's also possible to buy just the **** inserts that are reproduced.
https://www.dennis-carpenter.com/en/...-white-plastic
Old Aug 3, 2020 | 12:01 PM
1966F100SC's Avatar
1966F100SC
I bought new ones but had one original. To get the new ones to match I lightly sanded and then I took brown shoe polish to it. Now the new ones look like the original
Old Aug 3, 2020 | 12:37 PM
SwampRattFord
Ha, clever idea. I'm going the other direction. I've been replacing then one at a time for a year now.
Old Aug 3, 2020 | 12:42 PM
SwampRattFord
Thanks. The black part of the **** is in sad shape as well.
Old Aug 3, 2020 | 02:11 PM
resonateur's Avatar
resonateur
Swamp...I'm not sure, I'll have to check it when I get home....no worries if you're not interested. As TA stated above, you can also just get the white insert. I may even have on of those....will return!
Old Aug 3, 2020 | 07:27 PM
66v8baby's Avatar
66v8baby
I found an NOS '67 cable which of course has a different ****. I removed the **** using a heat gun, then threaded the stud and installed a new '66 style **** with a threaded insert. It looks like it came from the factory that way. The reproduction cables have a different type jacket that is much thinner, shinier and harder than the originals.
Old Aug 3, 2020 | 10:17 PM
resonateur's Avatar
resonateur
....yeah, the one I have has a crispy yellow center. If I were you, I would just buy a ****, burn the old one off, make sure the shaft has serrations on it, and epoxy the new one on. Most old choke controls will be the owner of just as old *****....
SwampRattFord
Aug 1, 2020 10:05 AM
Shadowrider123
Dec 6, 2014 08:05 AM
aidandj
13
Aug 4, 2013 11:44 PM
deyomatic
Dec 30, 2009 05:39 AM
cbfomoco
Feb 6, 2006 09:58 PM
