AN HONEST FORD DEALER
Old Jul 23, 2020 | 06:14 PM
StanleyZ's Avatar
StanleyZ
Towed my 5er from ATL to Bentonville AR. As I got close to the RV park I started hearing tire noise. Upon inspection the drivers side front was worn on the outer shoulder and cupping. I took the truck to the after market tire shop recommended by my son. I asked them to rotate the tires front to rear outside dually wheel and to align the front end. They put the truck in the bay and about 15 minutes later the nice man informed me that I had a bad ball joint and that it should be replaced. I thought about if for a bit and decided that was BS, they just wanted to work an old guy over a bit. So I declined saying I would take care of it when I got home. And I said I know you can't align it with a bad ball joint so just rotate the tires. They did and I left. The next chance I had to check the ball joint was in Oklahoma City. I took it to JOE COOPER FORD in Yukon. I told them I had been informed I needed a ball joint and please align the front end and change the oil. I left with a friend and about an hour later I got a call from the service advisor saying THE TECH SAYS THE BALL JOINTS ARE ALL FINE AND NO WORK IS NEEDED. I was amazed. Because I'm an old man they usually try to work me over a bit. So, if you are in the OKC area and need some work it might be worth your time to visit JOE COOPER FORD,
Old Jul 23, 2020 | 06:45 PM
jollyrogr's Avatar
jollyrogr
After reading all the horror stories about death wobble, do Ford service technicians know the difference between a good and bad ball joint?
Old Jul 23, 2020 | 07:01 PM
StanleyZ's Avatar
StanleyZ
I don’t know about death wobbles. This is my third super duty and my 20th year with one and I have never had the “death wobble” experience, nor do i want it lol
Old Jul 24, 2020 | 05:27 AM
fordboy2's Avatar
fordboy2
Glad to hear you found an honest shop. I’m. It surprised the tire place tried to work you over. Belle tire is notorious around here for finding stuff when you go in for a rotation. I also have never had the death wobble and I’ve probably had 20 plus of these trucks. I have 5 right at the moment. Lol
Old Jul 24, 2020 | 09:34 AM
longhaultransport's Avatar
longhaultransport
What caused the tire to wear like that?
Old Jul 24, 2020 | 03:50 PM
senix's Avatar
senix
Congrats on finding someone honest.
I just had a bit of cupping and therefore, had two tires from the rear moved to the front. Alignment perfect.
I was told it was my shocks that we causing it.
Last night I pulled one off, I had to wrestle it to compress it enough to re-mount it. Guess I don't need shocks.
Old Jul 26, 2020 | 03:56 AM
golfmedik's Avatar
golfmedik
I trashed my Ford shocks on my trip to Wisconsin a couple or years ago and replaced them with Bilsteins and all of a sudden, my tire wear went away too.
Old Jul 26, 2020 | 05:44 AM
senix's Avatar
senix
What model of the Bilsteins did you go with?
fishingrodburner
2004 - 2008 F150
Feb 23, 2017 10:07 PM
dmen
Oct 25, 2011 06:40 PM
FireTail-AR
Feb 10, 2010 08:33 AM
DieselCamper01
Aug 15, 2008 07:56 AM
merlins'92f250d
Mar 1, 2008 08:09 PM
