Gathering materials for Excursion Paint job and ?'s
Old Apr 9, 2020 | 08:57 AM
6_Myles's Avatar
6_Myles
Hi All, quick questions as I look towards painting this big thing:
I have a two-tone Eddie Bauer trim Excursion, looks like main body is G2, M7089A Redfire Metallic and trim panels are M7020A, M7026A, TK Mineral Gray Metallic. See below for an example
My questions:
1. Should i buy ready to shoot paint from a website? Or go to a local place to have them mix it?
2. Both are metallic paints. Would I be better to shoot these through the 1.8 or 1.3 gun? I assume the 1.8 but should I look for a another needle size?
3. The trim is plastic, do I need to get a specific type of paint for that?
4. I have a couple of areas that were rock chips or need surface rust repair. What primer would you recommend? Just buy from the same website as the base/clear or buy local too?
Thanks!
Old Apr 9, 2020 | 11:09 AM
Beechkid's Avatar
Beechkid
My questions:
3. Would I be better to shoot these through the 1.8 or 1.3 gun?
First off, there is no such thing...all paints require a catylist that must be mixed and sprayed in a specific time frame. They my be selling a pre-thinned paint but that it's no more, no less. IMHO, best to buy local for several reasons....1) you will get the proper reducer for your specific environmental requirements (temp, humidity, etc.), 2) you are getting the best line of paint for the $ and 3) you are buying from people who know the specific products in your area and know how to address the moisture, etc impactors to ensure a successful application
2. Would I be better to shoot these through the 1.8 or 1.3 gun
The paint MFG will have the specifics in their data sheets of what to use (because of flake composition/diameter, etc.)
3. I have a couple of areas that were rock chips or need surface rust repair. What primer would you recommend?
Paint is a chemistry class today...mixing brands or even specific product lines is NOT a GOOD THING and typically comes back to bite you....pick a mfg and stick with their recommendations
Old Apr 9, 2020 | 12:07 PM
6_Myles's Avatar
6_Myles
Buy local and let them tell me what I need! Got it.
Boss_hoss
Jun 30, 2010 01:07 PM
FD5150
Paint & Bodywork
Jan 4, 2009 09:26 AM
codys50ford
Oct 7, 2007 11:22 AM
Chevythunder7578
Paint & Bodywork
Jul 24, 2004 09:21 AM
Metalstorm
Bronco II
Nov 25, 2002 10:14 PM
