When you put a slide in camper on the truck which blocks the rear tailights, I will assume it will trigger Blind Spot system to say there is something close by
The Blind Spot Information System with
Trailer Tow can be turned off in the
instrument cluster. If the Blind Spot
Information System is turned off, then the
Blind Spot Information System with Trailer
Tow automatically turns off.
If you plug your camper into the 7 pin it thinks it's a trailer. I believe you can turn off BLIS through the setup of the "trailer".
