Switches Inhibit
Old Nov 15, 2019 | 06:20 PM
Roger Kelderman's Avatar
Roger Kelderman
Switches Inhibit
Is there a way to disable " security mode switches Inhibit" on my 2019 F250. its not referenced in the owners manual AND the Vehicle settings on the F250 doesn't mention it. Some Ford models let you turn it off. Is there another way to disable this? I put an aftermarket push button door code unlock on and this security mode won't let this work after 20 seconds.
Old Nov 15, 2019 | 07:52 PM
Krazykatz911's Avatar
Krazykatz911
deleted post
Old Nov 15, 2019 | 07:58 PM
Roger Kelderman
Switches inhibit mode
This is the security issue on newer Fords. Locks the switches and buttons after 20 seconds .
Old Nov 15, 2019 | 10:42 PM
Krazykatz911
deleted post
Old Nov 16, 2019 | 06:46 AM
crewzer's Avatar
crewzer
I’m not familiar with this security feature.
The gauges suggest the truck is a 6.2 gasser with XL or XLT trim. Tell us more about your truck configuration and options.
Jim / crewzer
Old Nov 16, 2019 | 08:08 AM
Roger Kelderman
Jim / crewzer
2019 XL 6 2 gasser ext cab long box. Trying to find out if you can disable the switches inhibit mode with a scan tool.. most higher end Fords have the menu setting you can switch on and off. Not this one. So I'm hoping it's an option for a scan tool.
Old Nov 16, 2019 | 12:36 PM
mhoefer's Avatar
mhoefer
Forscan and disable security mode, however, that’s going to cause other issues? I no security at all. Another way is when shutting off the truck, set it to ask security settings, you can disable motion sensor for pets, for example, you can disable alarm entirely for when you want to todo the door pads.
maybe also research if with Forscan you can change settings to recognize the door key pad? This should allow all security but if you enter door keypad code it won’t trigger the alarm.
Old Nov 16, 2019 | 12:49 PM
Roger Kelderman
I hooked up Snap On Zeus and I cant seem to locate the switch inhibit disable. Didnt seem to be part of the options. I dont care about the alarm. Nobody pays attention to them anyway. Lol. Any idea what menu it might me under?
misterbond
Sep 10, 2017 04:03 PM
JWA
21
Oct 3, 2016 08:06 PM
Glowplugger
Apr 9, 2016 07:24 PM
Sir.Dino
Nov 7, 2014 06:58 PM
splice1985
Apr 10, 2010 06:57 AM
