Blind Spot system ???
Old Nov 16, 2019 | 09:29 AM
Philcsag1's Avatar
Philcsag1
When you put a slide in camper on the truck which blocks the rear tailights, I will assume it will trigger Blind Spot system to say there is something close by
Is there a way to disable the System?
Thoughts please.
Old Nov 16, 2019 | 09:43 AM
HRTKD's Avatar
HRTKD
From the manual:
The Blind Spot Information System with
Trailer Tow can be turned off in the
instrument cluster. If the Blind Spot
Information System is turned off, then the
Blind Spot Information System with Trailer
Tow automatically turns off.
If you plug your camper into the 7 pin it thinks it's a trailer. I believe you can turn off BLIS through the setup of the "trailer".
Old Nov 16, 2019 | 11:08 AM
Philcsag1's Avatar
Philcsag1
Thank You
Im in the research process
Old Nov 16, 2019 | 12:09 PM
otea090's Avatar
otea090
Yes you can turn off BLIS easily in the main screen
akjam
Dec 26, 2021 10:27 AM
pspc271
Jul 17, 2019 10:52 PM
Mlambert22
Sep 3, 2018 07:51 PM
IndyMcDAN
Mar 30, 2018 05:39 PM
truckfella
Oct 6, 2015 02:23 PM
