Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
What is this?
Old Sep 27, 2019 | 07:14 PM
Nicks87F700's Avatar
Nicks87F700
What is this?
**** below column. Has a red cable which goes through firewall then back under floorboard...not to engine compartment.
Old Sep 27, 2019 | 10:18 PM
jmtbiggin's Avatar
jmtbiggin
PTO cable?
Old Oct 1, 2019 | 05:36 PM
Nicks87F700
Originally Posted by jmtbiggin
PTO cable?
I'm guessing the same...
Old Oct 1, 2019 | 05:40 PM
85e150's Avatar
85e150
Is it hanging in mid air or connected to something?
Old Oct 1, 2019 | 05:54 PM
Nicks87F700
The **** is firmly connected but doesn't pull or push. Keep in mind..there is no power yet. The cable is loosely threaded through firewall then back but not attached to anything visible. I'm guessing PTO.
Old Oct 1, 2019 | 07:57 PM
85e150's Avatar
85e150
OK, you have a dump truck. Is there a hoist under there, or did someone liberate it before it was parked?
Old Oct 1, 2019 | 09:09 PM
Nicks87F700
This truck was owner by the county...used as a salt truck. Spreader in back, belly blade, front blade. It still has all hydraulics and operator controls for each. I don't see anything resembling a hoist or where one would even mount.
Old Oct 1, 2019 | 09:19 PM
Nicks87F700
I was also thinking that because the cable is colored red..that might be a clue.. idk. I'll figure it out, just thought I'd ask.
My next step is to drop fuel tank to clean/remove rust, then reinstall and fill some. Then install a stand by battery I have.
Then Oil change
Tranny fluid is perfectly clean and perfect level. (I expected worse..just because..lol)
After all fluids checked, filled, and or replaced..then the moment of Truth..I'll turn it over.
Old Oct 1, 2019 | 09:25 PM
ford390gashog's Avatar
ford390gashog
It's a old cable type idle lock, should be able to twist and pull to adjust and lock idle RPM. Useful for PTO if equipped.
Old Oct 1, 2019 | 10:37 PM
85e150's Avatar
85e150
By hoist I mean is there a hydraulic lift to dump the bed?
Old Oct 5, 2019 | 09:43 AM
1979 Ford's Avatar
1979 Ford
Throttle adjustment or a way to control the gate on the sander.
Old Oct 9, 2019 | 12:18 PM
Nicks87F700
85e150...I haven't had the chance to figure out which is which but there are multiple handles in center console. I believed one is for the hydraulic dump bed.
hillcountryflt
May 28, 2019 12:51 PM
The_Scatch
15
May 12, 2019 09:06 AM
ArizonaF250
Dec 29, 2018 09:37 AM
amalone51
Sep 7, 2016 09:08 AM
shorebird
General Automotive Discussion
Sep 20, 2012 07:51 AM
