Shocks for 4" lift?
Old May 14, 2019 | 07:10 PM
jpcjguy's Avatar
jpcjguy
Shocks for 4" lift?
Hi all,
Have a 2002 4x4 7.3 with 4" Procomp lift that i put on in August 2010 at about 90,000 miles. I did the kit with the dropped pitman arm and drop bracket. At the time I took advantage of the Rancho 9000XL deal. So the RS999005 and the RS999344. Now the dials don't turn at all and I am just done with them....
Now I have 184,200 on her and she rides pretty bad. I run 35x12.50 BFG AT KO2 on 16x10 Weld Outbacks with 3.5" backspacing. I don't off road with her at all.
I am looking at the Bilstein 5100 that everyone seems to like. Just want to double check that I should get the following for my lift:
Bilstein 33236964 Shock Absorber - rear
Bilstein 33185545 Shock Absorber - front
Another question is would these be the same shocks if I stepped up to a 6" lift? Thinking if I move to 37s, I don't want to rebuy shocks. I might pursue different rims with more backspacing next go around also - Get a decent amount of rubbing.
Or I might do the trimming/zero rate spring that everyone is discussing to fit 37's with a 4".
Thanks,
Joe
Pics of my Ex: (Yes that is a Nitto on the rear in the pic - had a cut tire and there were no BFGs in my size on the entire eastern seaboard - had to make do)
Old May 15, 2019 | 06:40 AM
bluovl's Avatar
bluovl
I'm in the middle of installing a 4 inch lift on my 2002 Ex. I'm using the exact Bilstein parts you listed
Old May 16, 2019 | 06:16 AM
jpcjguy's Avatar
jpcjguy
Cool thanks for the confirmation. I wonder if these would be the same shocks for a 6" lift - would hate to have to replace them again....
Old May 16, 2019 | 06:52 AM
bluovl's Avatar
bluovl
According to Bilstein's product information 4-6 inch's of lift.
Old May 16, 2019 | 06:57 AM
jpcjguy's Avatar
jpcjguy
Sounds good
Sparky0486
Apr 11, 2012 08:41 PM
Clint40
Oct 24, 2007 03:58 PM
checkered02v10
Jul 2, 2007 06:40 PM
Badford
Nov 24, 2003 08:26 PM
