79 Ford Ford f250
Old May 12, 2019 | 06:31 PM
larrabee391's Avatar
larrabee391
79 Ford Ford f250
I recently changed carbs on my 79 Ford f260 460ci. I removed the Holley that was on it and replaced it with a new Holley 600cfm. On the old carb there were intake vaccum lines behind the choke, the new ones does not have that. I installed the new carb, new PCV valve, new vaccum lines. once I got the truck started it revved sky high. There is clearly a high idle issue and I'm at a loss on what to do. I'm learning this as I go so any help would be greatly appreciated.
Old May 12, 2019 | 06:45 PM
tabascom16's Avatar
tabascom16
Youtube is your best friend. Plenty of great videos getting your Holley dialed in. Don't think you can just take a carb out of the box, bolt it on, and expect it to work perfect. Setting idle, setting the floats, checking the spark plugs and putting in different jets, etc. to get it running great.
Old May 12, 2019 | 07:20 PM
larrabee391
Yeah I have searched high and low on YouTube and have yet to find anything. Best I can understand it is a either a vaccum issue or fuel pressure too high or a combination of the two.
Old May 12, 2019 | 07:38 PM
tabascom16's Avatar
tabascom16
Too high a fuel pressure and the needle won't close. It will be dumping huge amounts of gasoline down in your engine through the vent and should probably make it smoke like crazy, not rev sky high. The throttle plates in the two main barrels should essentially be completely closed at idle. It doesn't take much of these being open to make it rev high at idle.
Old May 12, 2019 | 07:46 PM
larrabee391
Once running it is very clear it is running rich. Would the addition of a small fuel filter before the fuel line enters the carb help reduce fuel pressure? Thanks
Old May 12, 2019 | 08:27 PM
biasvoltage's Avatar
biasvoltage
Best bet is a fuel pressure regulator. I bought a Summit branded one and it leaked, they sent another and it leaked too so I picked up a Holley branded one. Rock steady pressure, no leaks, I set it to 5psi.
halltm
Jul 3, 2011 02:41 PM
aaronesq
May 22, 2007 12:32 PM
cw76f100
Oct 23, 2005 09:52 PM
flyhound
May 30, 2005 09:28 AM
nsshull
Jun 2, 2004 09:30 PM
