Holley Help
Old May 12, 2019 | 08:07 PM
F-250 restorer's Avatar
F-250 restorer
Holley Help
Hey guys, I have a Holley 4160, an 1848, 465 cfm. It sat for 4 months while I changed the transmission from an auto to a manual. I changed the gaskets and blew through the primary side orifices. Had an issue eliminating a stumble, but found the right acc. pump discharge nozzle and the stumble vanished. However, after the initial take off, there is a lack of power as I gain speed and the rpms reach a certain level, then I get power. But, when I shift, the same thing happens again in the new gear.
Ideas? Is that due to too rich of an acc. pump shot?
Old May 12, 2019 | 10:40 PM
440 sixpack's Avatar
440 sixpack
I assume your timing curve has been checked and you have no vacuum leaks.
Is this the engine build you have listed under the picture ? if so you're really on the light side for carburation.
Old May 12, 2019 | 11:27 PM
F-250 restorer
[QUOTE=440 sixpack;18649732]I assume your timing curve has been checked and you have no vacuum leaks.
Is this the engine build you have listed under the picture ? if so you're really on the light side for carburation.[/QUOT
Yes, you may be right. The built 300/4.9's really do love a nice Holley 600. But, on the other hand, I have also run a Quadrajet, and the primary side of my QJ was right around 200 cfm, not taking into account the toilet flusher secondaries.
Classicdriver
65
Feb 14, 2017 08:45 PM
73 ford guy
Oct 1, 2012 10:15 AM
sunnybottomboys.de
28
May 27, 2012 05:55 PM
SeattleWills
Jul 13, 2009 08:15 PM
JNeptune
May 18, 2009 07:55 PM
