1952 f3 dome light wire routing
Old May 2, 2019 | 02:12 PM
52burjes's Avatar
52burjes
Hello, I am trying to figure out if wiring to dome light from fuse block and door switches is usually routed up cowl and window/door post and above headliner to back of cab or under carpet, up rear cab corner, above headliner to dome light. Is one way preferred over another?
Fuse block will be drivers lower firewall.
Thanks, larry
Old May 2, 2019 | 02:46 PM
TitusDH's Avatar
TitusDH
I think it took the same route as the tank sending unit wire: around the passenger door and not under the carpet.
Old May 2, 2019 | 08:54 PM
52burjes's Avatar
52burjes
Moved the gas tank, but i'll run it up driver's door and not under carpet. Thanks for the info, larry
Old May 2, 2019 | 11:30 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
That's how mine is routed. Across the dash (behind it) and up over the passenger door and across to the dome light.
Old May 3, 2019 | 07:35 PM
52burjes's Avatar
52burjes
Thanks for your input too, scotty. I"ll definitely run it up over a door and above headliner. Larry
GarrettM
Oct 30, 2015 01:37 PM
fordtruck661
Sep 4, 2013 09:51 PM
StevensPoint
Nov 29, 2007 08:10 AM
OAGES
Mar 10, 2004 10:12 AM
coopebc
1997 - 2003 F150
Jul 6, 2003 10:07 PM
