Buyers said they would fit
Old May 2, 2019 | 01:33 AM
Mixer man's Avatar
Mixer man
Was told they would be a perfect fit for 9R22.5's. Ha! These are poly fenders, can they be modified?
Old May 2, 2019 | 07:37 AM
raytasch's Avatar
raytasch
Believe Nothing
So what do they look like when they're raised about six inches? They would have enough clearance if you wanted to run chains.
Old May 2, 2019 | 07:55 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I agree, raise them up a bit and see what they look like. Other than that, no, I don't think there is anyway to modify the radius on poly fenders.
When the guy said they would fit, he probably had a whole different picture in his head that what you were meaning by "fit". I think you were wanting something with a closer matching radius, he was probably meaning that they would cover the wheel set without interference.
Good luck
Bobby
Old May 2, 2019 | 10:22 AM
52 Merc's Avatar
52 Merc
I agree with all of the above. I was thinking what Bobby said before I read his comment, on the fit, fitment thoughts, and modification ability.
Old May 2, 2019 | 10:44 AM
Mixer man's Avatar
Mixer man
I tried raising them but the radius doesn't look right. Also tried bringing the ends in but they buckle in the middle very easily.
Old May 2, 2019 | 11:06 AM
bigwin56f100's Avatar
bigwin56f100
I want to see a pic with them up 6"
Old May 2, 2019 | 11:49 AM
Mixer man's Avatar
Mixer man
They won't go that high without hitting the mixer barrel. 4-1/2" max. That's why I need the snug fit. And the mounting brackets fit to the outside and add another 5". I can fix the width by just sawing off some from the inside.
Old May 2, 2019 | 06:30 PM
CBeav's Avatar
CBeav
I think the bottom edges are meant to be about even with the center of the hub of maybe even slightly higher. Picture them with standard mud flaps on them. They may not work for your application but for most trucks... maybe.
Old May 2, 2019 | 09:02 PM
bobbytnm's Avatar
bobbytnm
The more I look at the pic I'm thinking that even if you raised them up a bit they still would look right. Yes, they'd work but I think that every time you looked at them you'd be dissatisfied.
How about fabbing something out of sheet metal. You could probably have some sheetmetal rolled to the radius you like and weld on some round stock at the edges to give you a nice rounded edge. A lot more work but you could get the proper radius
Bobby
Old May 2, 2019 | 11:51 PM
Mixer man's Avatar
Mixer man
Here the fender is raised five inches. It's hitting the barrel. These just aren't going to work for me. They are for 11R24.5's. I think even if I narrowed them by six inches and notched out for barrel clearance, they still wouldn't look right.
Thanks for all your input, guys.
Old May 3, 2019 | 04:38 AM
bigwin56f100
Well that looks way better. I see nothing wrong with that
Old May 3, 2019 | 08:36 AM
bobbytnm's Avatar
bobbytnm
I agree, I don't think they will work, the proportions just aren't right. The radius is too large and they seem a bit too wide also
Bobby
Old May 3, 2019 | 10:34 AM
Mr. Ed's Avatar
Mr. Ed
Too big and too wide. Send them back and ask the "seller" if he has anything smaller. If not, look for trailer fenders. They come in a variety of sizes.
Later!
Mr. Ed
Old May 3, 2019 | 11:09 AM
ReForder's Avatar
ReForder
I think "fit" is a rather subjective term here. Yes, your tires don't hit them, but yes, the radius is all wrong.
Good luck with the "seller". They may get a little defensive.
I also agree with Mr. Ed on the trailer fenders. Might take some more searching to find what you need, but there has to be something for a trailer that will fit back there, particularly a car hauler.
Old May 3, 2019 | 03:14 PM
Mixer man's Avatar
Mixer man
Considering two pair of these bolted together.
New Rear Fenders To Fit 1932 Ford Pickup - Hardison Metal Shaping
