My 1978 F150 fix her up thread
The more I worked at trying to get the front grille off, the more ROTTEN things I started to find. It is painfully obvious, this truck NEVER saw the inside of a garage or a shed of ANY kind.
SO..... rather than try to fix a few things at the time while I drive it..... I am going to pull the engine, take off all the body panes and do it right.
Some pics from this weekends eye-opening experience.
I knew I wanted to replace the grille but every time I took a piece off, I saw more rot underneath.
The headlight buckets had a bad case of cancer and the adjusting screws were toast.
Somebody had already "fixed" the one on the driver side...... the spring obviously had rotted and here was the fix......
See how bad the adjusting screws had gotten......
The inner fender under the battery tray was a mess...... New inner fender will fix this train wreck.
Also, you can see where the PO had cut the wire to the horn...... I guess he must have had the old "horn blowing on it's own" problem. This is one way to fix that problem. Just cut the wire...
EVERY one of the clips that serves as a nut (nut clip??) was rotten so there was NO WAY to take the bolts out of the front end without cutting the clip off.
SO... after a LOT of "nut cuttin'..." I finally got the front end this far along. LOTS more work to do..... But, It's gonna be done right.....
Here is another shot of the sorry dirt engineers work. The dang dirt daubers had built 2 nests INSIDE the ICU..... Even with this much of the filler plastic melted away and the dirt nests.... this unit was STILL operational. I drove this truck for 3 weeks before I started the tear-down.....
I'm SURE this won't be the LAST on of these nests I will find.
ONWARD!!.......
Mike
Here if and when you sawzall them out...go in between the bottom of the core support and on top of the frame. A cutting torch will make a unholy smoky fiery mess. lol
D3TZ-1000155-B.. Absorber (rubber cushion) -Lowerradiator support andlowerfront & rear cab mounts / Obsolete
CARPENTERNOS OBSOLETEPARTS in Concord NC = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX = 888-727-0418.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
D3TZ-1000396-C.. Absorber (rubber cushion) -Upperradiator support andupperfront and rear cab mounts / Obsolete
PARTS INTERNATIONAL
GREEN SALES CO.
PDF has better detail.
My wife gave me a sawz-all last year for my birthday.... so I can already see I will need to put it to work on my truck.
One good thing from this past weekend....
I broke aloose all of the exhaust manifold bolts without breaking any off....LOL... win-win.
That was one thing I never could do on ANY of my CJ or MB projects. There was ALWAYS 1 or 2 that would break off....
Mike
https://www.diablotools.com/
https://www.diablotools.com/explore/recip-blades
https://www.homedepot.com/b/Tools-Po...2jgZgeZ1z0vjtq
I will go see if I can find me some of those Red Diablo sawzall blades. As much rust as I have found so far...... I can see I will have to use those guys.
Mike
Need something cheaper than PB Blaster? ATF and acetone 50/50.
In my limited use of my sawzall has shown me that those dang blade will bend REAL easily.
Thanks for the recommendation!
I have already gone through 2 cans of PB.....
I mixed up a concoction that the gun folks call "Ed's Red"... It has acetone and ATF but also has 2 more ingredients I can't recall right away. (Maybe alcohol, mineral spirits)
But on guns.... that stuff works.
SO..... I'm gonna mix me up some home brew PB....
D3TZ-1000155-B.. Absorber (rubber cushion) -Lowerradiator support and lowerfront & rear cab mounts / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 13 = 800-476-9653.
PARTS INTERNATIONAL in Farmers Branch TX No longer in business.
GREEN SALES CO. in Cincinnati OH has none.
WESLEY OBSOLETE PARTS in Liberty KY No longer in business
CARPENTER NOS OBSOLETE PARTS has none.
GREEN SALES CO. has none.
1 part ATF (Dexron)
1 part Kerosene
1 part Acetone
1 part Turpentine or Mineral Spirits - aka "Varsol", stoddard solvent
Add up to 1 lb. of Lanolin from the drug store to make a longer lasting preservative.
1 part ATF (Dexron)
1 part Kerosene
1 part Acetone
1 part Turpentine or Mineral Spirits - aka "Varsol", stoddard solvent or charcoal lighter fluid.
AND... It works!
Check out this nice wire splice job..... If you can't find the problem, just JUMP over it.....LOL.
No tape, nothing..... just make sure the BARE WIRE doesn't touch anything and GO!!
What a joke!
problem is.....I'm not finding this crap very funny....
