1976 F700 conversion
Old Dec 20, 2018 | 02:23 PM
Working toy's Avatar
Working toy
I am taking a 1997 7.3 out of a truck and installing it in a 1976 F700, including the 5 speed and transfer case. Any preventative maintenance to the engine I should do while I have it on the floor, other than some minor oil leaks I need to address?
Old Dec 20, 2018 | 02:30 PM
z31freakify's Avatar
z31freakify
Re-seal the entire engine including injector O rings, oil rail galley plugs fuel system, and only using Motorcraft TA-31 to seal the intake plenums and oil pan. On the dipstick adapter to oil pan either weld it or buy the $300 gold nugget.
Optional:
-rebuild turbo/ add billet wheel
-rebuild turbo pedestal or buy deleted pedestal
-Mill the exhaust manifolds
-fabricate or buy bellow up pipes.
-freakify mod
-injector cups using Loctite 620 (green) so you can use ELC.
Old Dec 20, 2018 | 02:35 PM
ford390gashog's Avatar
ford390gashog
The above is spot on, the only thing to add would be inspect the oil cooler and change the o rings.
Old Dec 20, 2018 | 03:03 PM
knottyrope's Avatar
knottyrope
kewl project
Did you save the dash, IDM PCM and wiring harness?
This project was a fun one to watch and might give some ideas
https://www.ford-trucks.com/forums/1...d-rat-rod.html
rjp1965
Apr 27, 2017 09:31 PM
warwulf
Apr 30, 2016 06:55 AM
bkuuz1
Jun 2, 2014 05:47 PM
fordbroncodave
Jan 1, 2013 02:41 PM
1bigjoe
13
Apr 30, 2011 12:16 AM
