Oil everywhere and engine redlined on it's own
So...here's the saga. I have a early 2004 Exursion with the 6.0l (icp on rear of engine).
1. I had an injector stuck open and was blowing smoke / running rough. (diagnosed by Ford).
2. I had a turbo leak from what seemed like the center of the turbo.
3. I spoke with the folks at Hotshot Secret and purchased their product to see if it could free the stuck injector instead of replacing it.
4. I did a fresh oil change this morning and added the two quarts of hotshot secret (13 quarts of Rotella T5 and 2 quarts of hotshot secret).
5. I drove a little less than 50 miles.
6. Truck started running rough and died at a stoplight.
7. I waited a few minutes, and it restarted and I was able to limp it into a parking lot.
8. Pulling into the parking space it was barely running, and then it started revving on it's own...first time up to about 3000 rpms...came down to near idle and I turned the key off. It still revved on it's own up to about 4000 rpm before shutting down.
9. I got out, popped the hood and notice oil had sprayed all over the drivers side of the engine compartment.
...and that's when I called the tow truck and ordered some tacos to ease my pain.
Any thoughts or advice would be greatly appreciated.
Fuel into the oil (from a failed injector) dilutes the oil
Diluted oil fails to properly lubricate the turbo bearings
Unlubricated turbo bearings fail and oil gets into the intake (or even the exhaust when you have an EGR system that has failed open)
Oil acts as a fuel supply to the cylinders
Engine runs on its own
Failed injectors are a serious issue. When they are dumping fuel into a cylinder, no oil or fuel additive will help. Thinking these additives can fix any injector issue can delay a proper repair to the point of major damage.
Engine replacement is quite likely. To quote a fellow tech, "an unrequested increase in engine speed usually results in an unrequested engine replacement". Any time there's an engine runaway, there's no governed limit to the engine RPMs, meaning the engine ran at higher speed than its design limits. Factor in running the engine with fuel contaminated engine oil and it only compounds this effect on the bearings and all the engine internals.
I started a seperate thread and asked this question, but I thought I would ask here as well. If I wind up needing to swap the engine...
I've read a few threads where guys have swapped 06 / 07 engines into 03/04 F-250s. Apparently, it's a straight forward swap with the only issue they had to resolve being the length of the harness connection due to the ICP sensor location.
Are there any other issues that would come into play because of it being an Excursion vs an F-250?
Thanks
Thanks
Speaking of the turbo. Mine is an early production 04. Can anyone tell me if a turbo from a later year will work? Or if not, what else would have to be changed to make it work? Thanks.
