2003 F350 overhead display
Old Dec 9, 2018 | 05:27 PM
Lockholder's Avatar
Lockholder
my overhead display “works” but it will get dim then slowly get brighter then dim then brighter...
Old Dec 9, 2018 | 06:15 PM
akcooper9's Avatar
akcooper9
I had the same problem and sent it here for repair
https://www.ebay.com/itm/Ford-F150-F...item41605ef32e
Old Dec 9, 2018 | 06:33 PM
MoBill122's Avatar
MoBill122
Papa Smurf
I had the same problem, but after reading here and watching utube, soldered the diodes back in place myself. Takes some patience.... but doable.
Old Dec 9, 2018 | 07:33 PM
Lockholder's Avatar
Lockholder
two 680 were off and i resoldered them on but now it does the dim thing....
Old Dec 9, 2018 | 09:06 PM
pirate4x4_camo's Avatar
pirate4x4_camo
I had 2 off but a thrird one had a broken solder joint, it looked attached until I gently pry’ed it up, Resoldered it and now it works perfect.
Fwiw, solder wick works great for unsoldering and cleaning up boards when doing repairs.
Old Dec 10, 2018 | 08:55 PM
Lockholder's Avatar
Lockholder
so it works and just goes in and out and i solder it. poorly cause it's in a tight spot. whats more accuarate the miles to empty or the fuel gauge.
Old Dec 10, 2018 | 09:32 PM
timmyboy76's Avatar
timmyboy76
My 680's were mia, so i just soldered little jumper wires. Worked perfect and mpg is within .01-.4mpg off then hand calculated
Old Feb 16, 2019 | 07:30 PM
Lockholder's Avatar
Lockholder
two 680s that were loose or mia can i connect them together since space is limited or does it have to be individual...
Old Feb 16, 2019 | 09:10 PM
Lockholder's Avatar
Lockholder
so i fixed the little things and it works and its nice and bright the only issue i am having is that the temperature is reading -40...
Pete36
Mar 12, 2017 06:15 PM
Vinford
Jan 12, 2016 03:59 AM
Whitey Ford
Oct 9, 2010 04:43 PM
joejetson
Jun 15, 2004 05:48 PM
