2017 f350 brake controller
Old Oct 23, 2018 | 12:31 AM
Ronbraatz's Avatar
Ronbraatz
Brake controller quit working on my 2017f350 but works fine on my 2015 f350. No fault warning ,all light test are perfect except the recharge battery post on 7 way plug didn’t work I changed 30 amp fuse ,no difference . Breakaway works fine and everything is perfect with 2015?
Old Oct 23, 2018 | 05:18 AM
senix's Avatar
senix
should be under warranty, take it in. No fault dispay or warnings?
Old Oct 23, 2018 | 09:09 AM
HRTKD's Avatar
HRTKD
On my 2017, I have to press the brake pedal before the trailer gets 12v power to the battery circuit. Try that.
Old Oct 23, 2018 | 11:26 AM
rob17's Avatar
rob17
You don't charge you trailer batteries while driving down the road? You should have 12v to at the trailer connector as long as the key is ON.
Old Oct 23, 2018 | 12:34 PM
HRTKD's Avatar
HRTKD
Yes, I do charge the trailer batteries. But the truck has a "feature" that won't start power flowing to the trailer until AFTER the brake pedal has been pressed after you connect the 7 pin (and the engine is on I believe). I've tested this on mine and it will NOT start just because you connect the 7 pin. This question/issue comes up quite a bit on the 2017+ subforum.
Old Oct 23, 2018 | 01:39 PM
rob17's Avatar
rob17
Interesting, I wonder what the thought was regarding this "feature"? Pin 4 is the 12v I believe.
Old Oct 23, 2018 | 03:12 PM
HRTKD's Avatar
HRTKD
That Ford knows what is best for you.
andy's2000
Jun 15, 2017 07:23 PM
gtmustang00
All Things Towing
Sep 17, 2010 01:00 PM
cfd312
All Things Towing
Nov 8, 2009 08:08 PM
Sledhead4
May 24, 2003 12:32 AM
