Vibration with acceleration
Old Oct 22, 2018 | 05:12 PM
gwat's Avatar
gwat
Hi, new member here.
I just moved up from a reliable! 6.0 to a 2012 6.7 with 115k miles on it. The truck seems pretty tight (aside from a turbo oil leak) but I'm stumped on a vibration it has.
I can best describe it sounds like tire hum. Its only there when pressing the accelerator, let off and it immediately goes away. Definitely louder at lower speeds/higher load. When coasting I can make the sound by just very lightly pressing the accelerator. Does not change through the transmission shifts. 4x4 is working normally (ie transfer case/hubs aren't engaged).
Pretty vague I know. All the U joints seem tight.
Where else to look?
I'm obviously a 6.7 noob and very paranoid about my expensive purchase. I'm picturing a humming crank bearing or humming high pressure fuel pump....haha.
Old Oct 22, 2018 | 05:23 PM
seville009's Avatar
seville009
I have a 2006 f350 5.4l with about 64,000 miles on it that I think has the same noise you have. Only occurs under acceleration. Was told it was the rear pinion gears going. Haven’t done anything with it because it’s just a plow truck and gets about 1,500 miles a year on it. Has done it for maybe four or so years.
DanielT28
Jan 31, 2015 07:20 AM
jimlj
Jan 5, 2014 10:59 AM
BroncoBoss351
1978 - 1996 Big Bronco
Nov 28, 2005 01:32 AM
WME
Oct 14, 2005 09:31 AM
L8ndeb
Nov 13, 2001 12:34 PM
