1978 - 1996 Big Bronco
Vibration
Old Nov 7, 2001 | 01:10 AM
L8ndeb's Avatar
L8ndeb
Vibration
Hi Gang,
New problem of the day. The culprit: '90 XLT, 5.8, E4OD,
4 x 4, manual hubs and transfer case.
I get a LOUD (to the point of ear irritation) vibration hum when accelerating. It's kinda like a howl. It happens with 1/8 - 1/4 throttle. I can feel the vibration through the floor pan. Also, when the vibration is the loudest, it seems the truck has drag/resistance somewhere. You can feel the load change.
When the vibration occurs, if I let up on the gas it will subside and the drag (if any at the time) will disappear. The noise seems to be coming from the front half of the truck. All fluids up to snuff. I've looked at the exhaust, all seems to clear the frame.
Lastly, the vibration doesn't appear until after the truck has been driven about 5 miles and warmed up.
Any and all comers welcome.
Old Nov 7, 2001 | 07:18 AM
88BroncoXLT's Avatar
88BroncoXLT
Vibration
check your u-joints
Old Nov 7, 2001 | 09:42 AM
adelyser's Avatar
adelyser
Vibration
I had a similar problem on my '88 F-150. It ended up being the fan clutch was gone. I also agree with the U-joint tip.
Old Nov 12, 2001 | 11:17 PM
Riso79's Avatar
Riso79
Vibration
I had the same problem, it was the u-joints
Old Nov 13, 2001 | 12:34 PM
msuforeman's Avatar
msuforeman
Vibration
