66 F100 4WD FE throttle cable
Old Aug 6, 2018 | 10:11 AM
jonoaf's Avatar
jonoaf
Hey guys, yesterday my throttle cable gave out on my '66... I've found a lot of posts out there regarding cables but but not many of them are geared to 4WD and those that are have been for I6 engines. In my truck, someone replaced the original I6 with a 360 FE sometime in the past so I'm not sure what cable I would need.. I assume it would be the same as a 352 but that's why I'm checking in with you guys. I've seen C5TZ9A758AH listed in other posts for 352 engines but I also saw it's listed as 2WD only which puzzles me. Any suggestions for an original part number would be really appreciated but if you've been in the same situation and figured out an after market solution that doesn't require replacing everything from my linkage to my gas pedal I'm open to that too. I just want to get her back on the road.
Old Aug 6, 2018 | 10:47 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Yes, the MPC also doesn't seem to make it clear. But, the 1966 shop manual sure does. That cable you mention should be the one, correct for 1966 F100 4x4 352 among others. Here's the setup.
If you have the bracket on the firewall that looks like this then you should be golden.
Chad
Old Aug 6, 2018 | 11:18 AM
jonoaf's Avatar
jonoaf
Thanks so much for the quick response Chad! I'll check out to see if I have that firewall bracket tonight.
Jon
Old Aug 6, 2018 | 11:29 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The 1966 F100 4x4 with the 240 or 300 like you said your truck was originally - looks like they used about the same bracket so you could be in luck there. Everything in the cab is the same from what I can tell, so it's only from the firewall outward.
Chad
Old Aug 6, 2018 | 11:30 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If you feel like it post up your warranty plate info or a picture of it and I'll decode it for you - if you want.
Chad
Old Aug 6, 2018 | 12:35 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Starting in June 1965 with sequence number 696,001 and carrying through the entire 1966 year they changed to a "floating" gas pedal for the F100/250 2WD and for the 1966 F100 4x4. The assembly inside the cab that the accelerator pedal attaches to looks like this
C5TZ-9725-Z - Accelerator Assembly - 1 each
The accelerator cable attaches to the top round ball and the gas pedal hooks to the small round bar across the bottom. The gas pedal slips onto the bar and then there are these tiny little bushings that install on either end of the bar, then a "C" washer or circlip on the outboard ends. If you ever take it apart keep a close eye on these parts - they are available NOS and probably aftermarket, but if they aren't broken.....
C5AZ-9873-B - Accelerator Pedal Hinge Bushing - .189" I.D. x .234" O.D. x .125" long - 2 each
Chad
Old Aug 6, 2018 | 07:13 PM
jonoaf's Avatar
jonoaf
Here's some pics of what I got. Warranty plate is gone but the VIN is F11YL9858. I haven't gotten around to climbing under the truck to try and verify the VIN yet but as it's 4WD with 4 drum brakes I have a fairly high assurance the frame is right.
uknunn
Mar 30, 2014 06:17 PM
65_GarageArt
Feb 5, 2013 04:55 PM
ford66
27
Dec 23, 2011 10:25 PM
todd jo
Jul 3, 2009 05:16 AM
HardFordCore
Oct 13, 2004 02:27 AM
