66 F100 FE Throttle cable
Old Oct 12, 2004 | 04:54 PM
HardFordCore's Avatar
HardFordCore
Can anyone tell me what throttle cables will fit my 66 F100 with a 390/Cruiso and a Holley 4 barrel. Mine has finished its very long life so I need to go to the Pick&Pull to find something. Thanks.
Old Oct 12, 2004 | 10:59 PM
6t6merc's Avatar
6t6merc
I believe the '66 V8 cable is a one year only item. The '65 V8 part fits but has only one hole in the firewall bracket. My dealer had one a year ago, but can't find one now. I suggest you contact the dealers in your area and buy all you can find!
Eric
Old Oct 13, 2004 | 02:27 AM
camperspecial65's Avatar
camperspecial65
65 and 6 cable are same aside from bolt on outside...inside.....the 65 cable if you pull it out.....65 cable is thin cable, no plastic teflon type mat'l like was added in 66....66 is a far better cable....my 65 cabe ended up sticking...went to 66 cabe....runs great...smooth as glass....
cs65
