Brake Job Torque's
Old Jul 13, 2018 | 07:33 PM
c04678's Avatar
c04678
Brake Job Torque's
Have done lots of searching for the torque specs for my 2014 F250. The best I can find is generic, 42lbs for calipers and 165lbs for caliper bracket. I also found that some are saying that you need to use blue lock-tite on the bolts. Can anyone tell me if this correct.
Old Jul 13, 2018 | 09:37 PM
Just Strokin's Avatar
Just Strokin
Front Caliper is
F-250, F-350, tighten to 75 Nm (55 lb-ft).
Front Caliper bracket is
F-250, F-350, tighten the new bolts to 225 Nm (166 lb-ft).
Workshop manual does not call for Lock-Tite.
Old Jul 14, 2018 | 09:36 AM
HRTKD's Avatar
HRTKD
And don't forget to clean/lubricate the sliders.
Old Jul 14, 2018 | 01:56 PM
c04678's Avatar
c04678
The caliper bracket bolts did indeed have blue loctite on them. Will put some back on when I install the bracket.
There was some either anti-seize or grease between the rotor and hub. Anyone know which it may be?
Old Jul 14, 2018 | 03:44 PM
Just Strokin
Ford's Workshop DVD doesn't not state using any Lock-Tite in their repair procedures. Maybe the reason is the procedure shows the bolts are to be replaced.
I would use a good anti-seize with nickel in it. Permatex makes one.
Old Jul 14, 2018 | 04:17 PM
cappa's Avatar
cappa
Yup same here, I always use anti-sieze on bolts that are subjected to high heat like brakes and exhaust, haven't lost one yet.
Macrosill
Jul 25, 2015 06:22 AM
Macrosill
Jul 17, 2015 06:25 AM
ronjohn
Sep 8, 2012 09:04 AM
rcorcich
Jun 25, 2009 08:26 PM
