Have done lots of searching for the torque specs for my 2014 F250. The best I can find is generic, 42lbs for calipers and 165lbs for caliper bracket. I also found that some are saying that you need to use blue lock-tite on the bolts. Can anyone tell me if this correct.
Ford's Workshop DVD doesn't not state using any Lock-Tite in their repair procedures. Maybe the reason is the procedure shows the bolts are to be replaced.
I would use a good anti-seize with nickel in it. Permatex makes one.
