Torq-spec's
I'm looking for the torq spec's specific to my truck in Sig. for the Caliper bracket mounting bolts and the Slide pin bolts.
I found 166 or 203 lbs/ft for the mounting bracket and
27 or 42 for the slide pin bolt ??
Can anyone tell me which ones are right...
Thanks
Rich
From the Superduty Tech Folder:
Welcome to guzzle's Ford PSD Web Pages
Thru endless days of reading and link after link ,I thought there was a ford site that listed torq specs for year, make,model , I don't remember...
Thanks
Brake Caliper Bolts: 56 lb-ft (76 Nm)
Brake Caliper Anchor Plate Bolts: 166 lb-ft (225 Nm)
Brake Caliper Flow Bolt: 35 lb-ft (48 Nm)
Wheel Hub Extender Nuts: 130 lb-ft (176 Nm)
Brake Disc Shield Screws: 8 lb-ft (11 Nm)
'06 F-350 DRW (Rear)...
Brake Caliper Anchor Plate Bolts: 203 lb-ft (275 Nm)
Brake Caliper Support Bolts: 101 lb-ft (137 Nm)
Brake Caliper Flow Bolt: 26 lb-ft (35 Nm)
Disc-To-Hub Bolts: 89 lb-ft (121 Nm)
I had a **** moment with that last question. All worked out well . I had a seized bottom caliper slide bolt and top caliper piston start to seize with a torn boot,brakes dragging ... did a rear brake job and replaced most of driverside rear mechanical. Plus serviced the rear w/Amsoil severe gear and a new Mag-hytek cover (my fathers day present) and a tire rotation on the dually.Getting ready to tow the 5th wheel on vaca. for the 4th July .
Rich
