Sponsored by: Real Truck
Shift Lever Adjustment?
Old Jun 18, 2018 | 03:15 PM
Mitragorz's Avatar
Mitragorz
I just picked up a 2001 F250 SD with the 5.4. I also have a 1999 that is nearly identical (minus the 2001 having A/C)
Something strange I noticed is the the shift lever in the 2001, in Park, is damn near up against the dash, less than a finger length away, The lever on the '99 is right where you'd expect it to be.
The indicators in both trucks are lined up properly, but I'm rubbing my knuckles every time I shift the '01 into or out of Park. Is there any other adjustment? Nothing seems to be bent, and neither steering column is adjustable.
1999:
2001:
You can see in the photos how much closer it rests. There's also much more play in the '01. In the '99, I can pull the shift lever straight back about 2" from its resting position. The '01 can be pulled over 3-1/2" Not sure if that really means anything.
Old Jun 18, 2018 | 03:27 PM
brian42's Avatar
brian42
Veteran: Navy
Not exactly the issue you're having but this might give you some ideas of what to start looking at:
https://www.ford-trucks.com/forums/1...o-shifter.html
Old Jun 18, 2018 | 03:59 PM
Mitragorz's Avatar
Mitragorz
Thanks for that link, I'll try to check out that bushing when I have a little spare time from the wife and kids.
Old Jun 18, 2018 | 08:35 PM
finn's Avatar
finn
The die cast aluminum shift tube wallows out where the shift lever is pinned into the tube. Probably needs a new tube.
Old Jun 19, 2018 | 12:29 AM
RyanEJ25's Avatar
RyanEJ25
I thought I had it bad with sloppy play and bad bushings lol.
Mitragorz
Aug 14, 2018 03:13 PM
Hauland
Apr 9, 2018 06:32 AM
ford76460
Apr 14, 2017 04:04 PM
starrider
Sep 6, 2010 09:15 AM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
