Sponsored by: Real Truck
2015 F350 Lariat power rear sliding window stuck
Old Jun 16, 2018 | 10:28 PM
Long Haul's Avatar
Long Haul
Anybody have any suggestions on how to get a stuck rear sliding power window closed ? Its all the way open and will not close at all, won't budge by hand either.
The motor is getting power because I can hear it click when the switch is pressed. I had my brother tap the motor while I worked the switch back and forth still no go.
I tried getting it started closed by hand while my brother worked the switch, still won't budge.
I'm at a loss on this one guys !! Luckily the weather is supposed to be good overnight, but I have to get this thing closed.
Old Jun 17, 2018 | 03:23 AM
seville009's Avatar
seville009
Bunch of threads, but not many solutions. This thread explains how to get at the motor
https://www.ford-trucks.com/forums/1...l-the-way.html
maybe try pushing the open button then quickly switch to presding the close button while somebody is pushing the eindow each way?
Old Jun 17, 2018 | 05:41 AM
The Bone's Avatar
The Bone
I bet the cable is stuck. Not sure you can fix it without replacing the cables. Not sure you can get this from parts store. may nave to go to dealer.
Old Jun 17, 2018 | 06:41 AM
Long Haul's Avatar
Long Haul
We tried about everything last night after dark with no luck.
I'm going out now to try working on it some more now that the sun is up and I can see a little better.
Thanks
Old Jun 17, 2018 | 08:57 AM
Long Haul's Avatar
Long Haul
The cable was bound up inside the motor it would appear.
We couldn't break it loose for nothing so I just cut the cable and closed the window by hand..The whole motor assembly is riveted, so unless you want to drill the rivets out, there doesn't appear a way to take it apart to free up the cable. We did verify power to the motor BTW.
I'll just take a small piece of Gorilla Tape and tape the bottom of the window to keep it shut.
I'm not real pleased right now....
Old Jun 19, 2018 | 06:51 AM
The Bone's Avatar
The Bone
You will have to replace the entire back window. They cost about $500. I had to replace mine once already but for a different reason. Safeflight replaced mine. They had them in stock. It's only a ford part though.
Old Jun 20, 2018 | 07:13 PM
07 F250 Aggie Mobile's Avatar
Just had this happen to me again on my 2012 F-250, I pulled on the window while my Son constantly toggled the switch and after about 10-15 minutes, it finally moved
a few times all the way to the closed position. Had this same issue on my 2007 F250, replaced the motor and cable tray, bought parts from dealer. Did not need to replace
window back then. Would like to fix now so this doesn't happen again.
Old Sep 16, 2024 | 01:14 AM
wmcclure's Avatar
wmcclure
3rd Gear
Cable rusted and will snare .
amadas350
Jan 27, 2011 06:37 PM
theringworm
Jun 14, 2010 09:16 AM
sailorjohn
Bronco II
Feb 25, 2008 04:27 PM
one5150fisher
2004 - 2008 F150
Apr 19, 2007 12:28 PM
ScottVP
Electrical Systems/Wiring
Apr 14, 2003 02:42 PM
