No trailer brake/turn signal drivers side
Old 05-22-2018, 08:13 PM
tommyl's Avatar
tommyl
tommyl is offline
'99F350sdf. My left brake/turn signal is not working. The #1 7.5a fuse(under hood) is good and there is power in/out of it. I do not have power to the connector that is under the truck bed by the spare tire. So I am thinking about running a new wire from front to back. So the question, Where does the wire go after it comes out of the fuse bounder hood). I can see four plug connectors under the fuse box, is it one of them?
Old 05-22-2018, 10:06 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
I had to remove a connector in my trailer wiring because of a similar problem. I traced power to that connector but try as a might couldn't get it to pass through to the other side. Removed the connector and soldered the wires together - problem solved.
Just to the right of the fuse box there is a bundle of wires running up to the turn signal switch. The left turn signal lead should be light green with a white stripe assuming your 99 is the same as my 2000.
Old 05-23-2018, 03:18 PM
Tugly's Avatar
Tugly
Tugly is offline
I lost my trailer brakes and chased it down to the pigtail: https://www.ford-trucks.com/forums/1...tle-piggy.html
Old 05-23-2018, 03:33 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
if i remember right the 99's had 2 - 7.5A fuses for the trailer brake/turn signals. 1 was for the left bank the other is for the right. i dont remember which spot was which.. but i know one of them was in the #1 fuse location and the other was in the #3 location. Since you checked number one location try the other.
Old 05-23-2018, 03:36 PM
dn29626's Avatar
dn29626
dn29626 is offline
On my 2001, left is #1 and right is #3.
Scott in TX
10-20-2014 06:57 PM
rgp
1983 - 2012 Ranger & B-Series
09-13-2014 12:16 PM
SteevenH
1997 - 2003 F150
03-29-2010 10:33 PM
bohiaa
1999 to 2016 Super Duty
05-06-2009 12:26 AM
jamesu
12-10-2008 12:37 AM
Quick Reply: No trailer brake/turn signal drivers side
