Cargo Capacity for 2002 Excursion 4x4 7.3
Old 05-21-2018, 11:43 AM
PopsDad's Avatar
PopsDad
PopsDad is offline
I have a 2002 4x4 Excursion with 7.3 diesel. I removed the back seat and plan to put as many 20 lb pavers as I can without being dangerous. All the weight charts I look at seem to focus on trailer towing. I am not using a trailer. It has rancho's adjustable shocks and cooper all terrain tires. Any body know the weight I can carry in the cargo area?
Old 05-21-2018, 04:38 PM
F250_'s Avatar
F250_
F250_ is offline
Take your GVWR and subtract your vehicle weight.
Old 05-23-2018, 10:27 AM
PopsDad's Avatar
PopsDad
PopsDad is offline
Thanks Pete, I appreciate the answer.
So, I found out GVWR is 9,200. Last time I was on a scale the truck weighed about 8000 lbs (its true). That leaves me 1200 lbs to work with. I (me and my gut) eat almost 20% of that. (no pun intended).
We moved the pavers before I did the computation. They put 130 twenty pound pavers in the cargo area adding 2,600 lbs. Which is way over the recommendation. We made it safe, thank the Lord, and it actually drove find and the engine acted as if there was no load at all. It was way down in the back, but the front wheels stayed on the ground. I guess we were lucky. But we wont do that again.
Old 05-23-2018, 12:39 PM
jh818's Avatar
jh818
jh818 is offline
You'll need to make 3 trips.
dcullen
04-29-2020 08:45 PM
Phillip Darrin
06-08-2019 09:28 AM
Hesson81
Fifth Wheel & Gooseneck RV Towing
05-01-2019 10:46 AM
Jonesy Jones
08-02-2017 11:41 AM
jcobb124
09-06-2010 05:11 PM
Quick Reply: Cargo Capacity for 2002 Excursion 4x4 7.3
