Need Smog but have glow plug codes.
Old 05-19-2018, 04:54 PM
Tormz's Avatar
Tormz
Tormz is offline
I have a e99 7.3 and the time has come to get a smog(CA). Truck is back to stock but I have had glow plug codes and they have been on for some time. P1391&P1393. Plugs are motor craft and ohmed within all desired ranges as well as relay testing out good. Valve cover gaskets were replaced. Just need a idea where to start next.
Thanks.
Old 05-20-2018, 10:44 AM
Stebs's Avatar
Stebs
Stebs is offline
If all the wiring is good between the gpcm and the plugs, then next place to look at would be the gpcm
Old 05-20-2018, 12:13 PM
Tormz's Avatar
Tormz
Tormz is offline
Only have the relay
Old 05-20-2018, 02:42 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Did you replace the harness that goes to the glow plugs? It's different from the valve cover harness.
Old 05-20-2018, 03:01 PM
Tormz's Avatar
Tormz
Tormz is offline
Yes it was replaced. I double checked continuity and checked the 3 fusible links there aswell
Old 05-21-2018, 12:04 AM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
It is either the relay or the shunt. The shunt is that metal strap on the right side of the relay. You have a CA model E99. There are not too many of those around. Since you have codes for both banks, my money is on the relay but a good multimeter will tell you for sure
Old 05-21-2018, 12:09 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
Could be the GPR itself. Here's a link to Guzzle's write up with info on testing and the Stancor mod.
Be sure to complete the "drive cycle" after you clear the codes or it will fail again.
Old 05-21-2018, 09:18 AM
J.L.G.Jr.'s Avatar
J.L.G.Jr.
J.L.G.Jr. is offline
California is a big pain
Old 05-21-2018, 12:23 PM
Bonanza35's Avatar
Bonanza35
When mine went out in Wyoming years back, they got rid of that shunt, metal strap, and installed it without. Has worked fine for years. I keep the old parts but never had to put them in.
Old 06-07-2018, 08:37 AM
SeaBassHWD's Avatar
SeaBassHWD
SeaBassHWD is offline
Did you ever figure this out? I have the same truck, same codes and same issues with getting smog next month.
Old 06-07-2018, 08:44 AM
Tormz's Avatar
Tormz
Tormz is offline
The new relay from auto zone didn’t last a week. I replaced it with another autozone one Cleared my codes and drove around with a hot truck long enough to have the computer run the misfire and cc monitors. It passed smog that day then the relay failed 2 days later. I ordered up a white Rodgers gpr and will be mounting that next.
Old 06-07-2018, 11:02 AM
The Brad's Avatar
The Brad
The Brad is offline
As far as I know, 99.5 is the cutoff for smog tests. I didn’t think you had the smog an E99. Did something change?
Old 06-07-2018, 12:46 PM
Bonanza35's Avatar
Bonanza35
I have to smog mine. It was built 9/98. The model year is 1999 so you have to smog it.
Chet
Old 06-07-2018, 01:18 PM
brian42's Avatar
brian42
brian42 is offline
It's all based on OBDII compliance. CA doesn't smog '98 and earlier diesels because of this. Dodge, Chevy, and Ford all started a new "generation" of their HD truck lines in '99 and they were OBDII compliant. I'm not sure about the others but the Superduty was only partially compliant (which is why you have to get a specific "bundle" to fully communicate with our trucks) but have enough general code capabilities to still be enough for the state to ensure you're compliant-ish . That is why your '99 will always be tested (even the E99).
The down side is that our trucks will always be tested but the silver lining is that they can only read the things that actually set the SES light. Soft codes like the AIH and EBPV don't set off the SES and you won't be hit by those on a smog test.
Old 06-07-2018, 02:51 PM
beef tits's Avatar
beef tits
beef tits is offline
I did the "Stancor" relay and have been trouble free so far. My Alliant relay failed after like 2 weeks.
The Stancor is no longer made by Stancor, it seems. I forget the brand but ordered mine from a trusted source and it came with different labelling.
Quick Reply: Need Smog but have glow plug codes.
